Removing the tacho drive worm gear from a honda sohc
tifrap
PostPosted: 02:09 - 25 May 2015    Post subject: Removing the tacho drive worm gear from a honda sohc Reply with quote
Hi. I'm new here, but have been enjoying reading threads for ages now, and at last I've come up with a constructive question for my first post.
I discovered that the tacho drive worm gear (the one that is driven by the centrifugal oil filter) on my project wreck has only half of its allotted teeth. So I tried to remove it.
At least I didn't have to worry too much about damaging it, so levering it with a screwdriver, attaching a mole grip and 'surprising it' with a mallet, pulling it with a pair of long nosed pliers, and all of them together, did nothing at all.
When I cleaned up the bottom of the gunge filled hole that should be where the tacho cable fits I discovered that there is an oil seal deep down in the casing.
So I figure that I was just being too tentative ~ but before I get serious with it, I though I'd defer to the centuries of combined wisdom that exists here on the forum.
Anyone here ever got one out before? And more importantly got another one back in?
Any tips?
Should say that the engine is a Japanese made Honda cb100n, but essentially the same sohc engine as the cb125s xl, sl, tl 125 family.
CaNsA
PostPosted: 03:13 - 25 May 2015    Post subject: Reply with quote
Have you checked out the microfiche?
Suntan Sid
PostPosted: 11:13 - 25 May 2015    Post subject: Reply with quote
I assume you mean part number three on this page:-
https://www.cmsnl.com/honda-xl125-k0-usa_model825/partslist/E++05.html
I removed this part from my XL, I don't remember it needing much force to get it out.
There is an oil seal and thrust washer that need to come out before you can remove the whole thing.
If it's not turning and siezed you need to sort that out first!
tifrap
PostPosted: 16:10 - 25 May 2015    Post subject: Reply with quote
Thanks for replying CaNsA and Suntan Sid.
I had looked at quite a few of the cmsnl cb125 diagrams, where it's absent, but not the xl125.
Yes part number three is the one - the thing isnt seized, just not sure how to get at that oil seal and thrust washer down at the bottom of the cable fitting hole.
Am i right in assuming that the thrust washer is held in place by the oil seal - so it should follow it out?
Suntan Sid
PostPosted: 17:15 - 25 May 2015    Post subject: Reply with quote
Yes!
IIRC I got the oil seal out with an awl, (small pointy thing, for the uninitiated), the thrust washer came out the same way!
tifrap
PostPosted: 00:45 - 26 May 2015    Post subject: Reply with quote
Thanks Suntan.
The last post was made 11 years, 126 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.88 - MySQL Queries: 13 - Page Size: 48.15 Kb
