Making my PC sound better
Bike Chat Forums Index -> The Geek Zone Goto page 1, 2  Next
Northern Monkey
PostPosted: 21:40 - 26 May 2015    Post subject: Making my PC sound better Reply with quote
I'm on the hunt for a little more sound clarity from my PC.
I don't want to go full hifi nerd and spend thousands on making my spotify stream sound better, but I'll spend a few hundred trying to get that clearness that I hear in a nice hifi system. I used to run a NAD CD player and amp into a pair of floorstanders but I haven't room for it on my desk. I don't need loud, anything but, so suggestions of bazzillion watt bassboosta systems with the clarity of a mobile phone loudspeaker are not needed
I'm mostly listening to spotify (High quality) through a soundblaster Z soundcard, then into, currently a pair of creative gigaworks t20 speakers. I'm fairly sure it's these speakers that suck the life out of everything I listen to.
There isn't much space on my desk, unless I swap out the monitor, so I'm after suggestions that fit into the limited space available
https://img.photobucket.com/albums/v284/geoffhill/2BAF0428-35C0-46B7-ACA4-21BD7DBF6148_zpskclfe7of.jpg
Halp Plz
UncleFester
PostPosted: 21:42 - 26 May 2015    Post subject: Reply with quote
Decent set of headphones.
2017 Z1000SX
CaNsA
PostPosted: 21:44 - 26 May 2015    Post subject: Reply with quote
https://www.amazon.co.uk/Logitech-Multimedia-Theatre-Speaker-System/dp/B0006LCMK4
I use those, pretty good.
Seb
PostPosted: 22:56 - 26 May 2015    Post subject: Reply with quote
I switched from a Creative 7.1 setup to some Bose Companion 20s after dabbling with them and a pair of B&W MM-1s as well as a few other 2.1 setups.
The bass on the Bose is a little OTT at times but they deliver a really vibrant beefy soundtrack regardless of volume, whilst the B&Ws were much more refined, they felt a bit flat by comparison.
The only 2.1 system that genuinely impressed me was Corsair's SP-2500, bit more pricy than the Bose but worthwhile if you intend on cranking the volume up fairly loud, the massive subwoofer was a bit of a deal breaker for me though.
2010 Triumph 1050 Sprint ST
trevoriv
PostPosted: 23:13 - 26 May 2015    Post subject: Reply with quote
I've had headphones only for a couple of decades now, never had the need for speakers when I've got seperates elsewhere and come into my office to escape! Currently using AKG K141 and AKG K702, I find even the 141's can easily pick out the difference between lossless and compressed audio.
The Artist
PostPosted: 23:17 - 26 May 2015    Post subject: Reply with quote
Logitech sets are great quality usually. I am running a Z 5500 7.1 kit which sounds pretty good. Not quite as good as when I had a couple of active monitors on my desk though. They were the nuts but lacked bass. If you spend most of the time sitting directly in front of the speakers, have a look at active monitors.
Tritey This post is not being displayed because the poster is banned. Unhide this post / all posts.
UncleFester
PostPosted: 12:58 - 27 May 2015    Post subject: Reply with quote
I have a set of the old Logitech Z5500 - nice sound but the main speakers are a bit thin. Bass is great from the sub.
Ended up replacing the drive units for https://www.crutchfield.com/S-BXSbYD4V24z/p_133SBHEP20/Panasonic-SB-HEP20-Light-ash.html
They worked ok - made the sound a lot richer.
However, the AKG845 headphones i got when i had to deal with neighbours blow the soundquality of the other stuff into the weeds.
If i was upgrading a small office setup and i wanted good sound, i'd go for headphones and a decent Asus Xonar card every time again.
2017 Z1000SX
Northern Monkey
PostPosted: 15:28 - 28 May 2015    Post subject: Reply with quote
I don't really like headphones, I tend to have music on in the background while I'm reading or doing work.
I was happy with the speakers until I compared them with a cambridge audio go, and then realised how turd they sound in comparison.
RhynoCZ
PostPosted: 15:58 - 28 May 2015    Post subject: Reply with quote
You need some bigger speakers, if you want full and warm sound. The speakers don't have to be expensive, it's all about the dimensions and sometimes the design.
I'm anti subwoofers and I wanted something to fit on my table, so I got rather cheap Genius SP-HF1250B. RCA out + EQ (bass/treble) + wood. The high frequencies are crystal clear and the middle and low frequencies/basses are surprisingly very warm and full. I have the system EQ in the PC set on, what you could call, ROCK.
Not a bad pair for 25 pounds or so. The 100mm mid/low freq. speakers are just enough for use on your desk. Thumbs Up
ferrisio
PostPosted: 17:39 - 28 May 2015    Post subject: Reply with quote
I'd be tempted by some active studio monitors, something like https://www.thomann.de/gb/alesis_elevate_5.htm for £100. Means you don't need a subwoofer, a lot of small speaker systems sound good but lose stereo image due to the crossover frequency to the sub being so high because of their small size.
BMW R1100R
Northern Monkey
PostPosted: 18:37 - 25 Jun 2015    Post subject: Reply with quote
Looked at studio monitors, but too many ponds.
With a bit of buggering about, and rearranging, got some old Wharfdale speakers down from the loft, and bought myself a Cambridge Audio amp from richer sounds for £80
https://img.photobucket.com/albums/v284/geoffhill/IMG_7964_zps5zwtbdgh.jpg
Everything is now about eleventy times clearer than it was before.
Proper hifi, even cheap stuff, sounds like proper hifi.
Accuhaler
PostPosted: 19:20 - 25 Jun 2015    Post subject: Reply with quote
Can agree with others getting Logitech speakers will make it sound better using the X-540, using on board sound inputs to my motherboard!
Dalemac
PostPosted: 21:07 - 25 Jun 2015    Post subject: Reply with quote
I have those as well. I've had them for like 8 years and still enjoy the sound on them.
I'll not replace them until they go bang. When they do, i'll buy another set of logitechs.
YBR125 -> GPZ500S -> SL1000
el_oso
PostPosted: 21:55 - 25 Jun 2015    Post subject: Reply with quote
why not? (not rhetorical)
A half decent pair of open air cans can really minimize the amount you feel closed in by some headphones. There are also wireless options if you don't like cables.
For background noise i carry around a smaller anker bluetooth unit to provide noise in a room. If I can, I play things through the HiFi. For office work I use headphones.
Duke 390
Car: Jeep Wrangler 4.0L
Northern Monkey
PostPosted: 22:12 - 25 Jun 2015    Post subject: Reply with quote
I get hot ears, and I forget to take them off when I get up to make a cup of tea. Wireless ones are heavy.
PostPosted: 23:48 - 25 Jun 2015    Post subject: Reply with quote
Miles better I imagine.
I have some 9.1 wharfedales and can't fault them when used in a small room. Check the 9.1s out if you fancy a slight upgrade.
Blu-tac under each corner of the speakers should give a clearer sound too, or if you can source some dense foam and cut them into wedges you can aim the tweeters at your ears and the dense sponge helps to decouple the speakers from the desk. Bestest and cheapest upgrade to any speaker.
Northern Monkey
PostPosted: 10:06 - 26 Jun 2015    Post subject: Reply with quote
If I were to upgrade the speakers, it would probably be to some Q Acoustics 3020, but with a pending house move, that's an upgrade that will have to wait
PostPosted: 10:38 - 26 Jun 2015    Post subject: Reply with quote
Nice speakers with excellent reviews. If you don't already know rear ports won't like being close to walls/corners.
[edit] Their manual mentions using the supplied foam bungs....which I've never been a fan of. Kinda defeats the design and reduces the Bass performance IMO.
...Apologies if I'm going all audiogeek.
Northern Monkey
PostPosted: 10:59 - 26 Jun 2015    Post subject: Reply with quote
I never listen at volumes much above normal speech levels, so efficiency and bass performance aren't a huge concern. They will be located in a similar manner to the current setup, close to the wall, and within 1m of the seating position.
IMHO, lower volumes seem to demand better performance from audio kit, which is why the previous set up seems to come up so short
The Artist
PostPosted: 13:07 - 26 Jun 2015    Post subject: Reply with quote
Active monitors are the only way to go for close range high quality sound. When my PC was on a normal desk, they were amazing. Now I use my TV as the screen so I just use my normal Logitech 5.1 set but if I ever go back to a desk, monitors will be bought.
Northern Monkey
PostPosted: 13:17 - 26 Jun 2015    Post subject: Reply with quote
I did consider Adam A7X for a very short while, but the £800 price point well north of my budget for the moment.
The Artist
PostPosted: 17:22 - 26 Jun 2015    Post subject: Reply with quote
There are monitors and there are monitors.
I had a pair of these. They can be picked up for ~£150 on ebay for a pair of used ones.
https://www.ebay.co.uk/itm/Behringer-Black-75W-Truth-B2031A-Boxed-In-Pairs-/281589619692?pt=LH_DefaultDomain_3&hash=item41900c9bec
Not top of the line but still a massive step up from non monitors.
PostPosted: 18:24 - 26 Jun 2015    Post subject: Reply with quote
Active monitors in the main get used in the studio because they tend to offer a relatively flat EQ and are easier to transport. They are not designed to flatter or enhance the sound unlike Hi-fi speakers. Some studio monitors can get quite tiring on the ears.
Just saying like.
There are no real rules but the guidelines could make your ear happier and save you money, especially if you audition say the Adam against some Dali.
ferrisio
PostPosted: 19:40 - 26 Jun 2015    Post subject: Reply with quote
Adams are a good example of this as they have a ribbon tweeter which I found quite easy on the ears (I had S3s), but I never got on with for mixing as I didn't find they translated well.
For use as hifi speakers though, they were very pleasant. Tannoy dual-concentrics are another good example of this.
BMW R1100R
The last post was made 11 years, 66 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.34 - MySQL Queries: 13 - Page Size: 133.12 Kb
