| Northern Monkey |
 Northern Monkey World Chat Champion
 Posted: 21:40 - 26 May 2015 Post subject: Making my PC sound better |
I'm on the hunt for a little more sound clarity from my PC.
I don't want to go full hifi nerd and spend thousands on making my spotify stream sound better, but I'll spend a few hundred trying to get that clearness that I hear in a nice hifi system. I used to run a NAD CD player and amp into a pair of floorstanders but I haven't room for it on my desk. I don't need loud, anything but, so suggestions of bazzillion watt bassboosta systems with the clarity of a mobile phone loudspeaker are not needed
I'm mostly listening to spotify (High quality) through a soundblaster Z soundcard, then into, currently a pair of creative gigaworks t20 speakers. I'm fairly sure it's these speakers that suck the life out of everything I listen to.
There isn't much space on my desk, unless I swap out the monitor, so I'm after suggestions that fit into the limited space available
https://img.photobucket.com/albums/v284/geoffhill/2BAF0428-35C0-46B7-ACA4-21BD7DBF6148_zpskclfe7of.jpg
Halp Plz ____________________ Fisty: after polishing the tank with the glistenng beads of sweat from my full hot scrotum, I filled the headrace bearings with 10cc of my manmilk |
| UncleFester |
 UncleFester World Chat Champion
| CaNsA |
 CaNsA Super Spammer
 Posted: 21:44 - 26 May 2015 Post subject: |
| Seb |
 Seb World Chat Champion
| trevoriv |
 trevoriv World Chat Champion
| The Artist |
 The Artist Super Spammer
| Tritey |
 Tritey Banned
| UncleFester |
 Posted: 12:58 - 27 May 2015 Post subject: |
I have a set of the old Logitech Z5500 - nice sound but the main speakers are a bit thin. Bass is great from the sub.
Ended up replacing the drive units for https://www.crutchfield.com/S-BXSbYD4V24z/p_133SBHEP20/Panasonic-SB-HEP20-Light-ash.html
They worked ok - made the sound a lot richer.
However, the AKG845 headphones i got when i had to deal with neighbours blow the soundquality of the other stuff into the weeds.
If i was upgrading a small office setup and i wanted good sound, i'd go for headphones and a decent Asus Xonar card every time again. ____________________ 2017 Z1000SX |
| Northern Monkey |
| RhynoCZ |
 RhynoCZ Super Spammer
 Posted: 15:58 - 28 May 2015 Post subject: |
You need some bigger speakers, if you want full and warm sound. The speakers don't have to be expensive, it's all about the dimensions and sometimes the design.
I'm anti subwoofers and I wanted something to fit on my table, so I got rather cheap Genius SP-HF1250B. RCA out + EQ (bass/treble) + wood. The high frequencies are crystal clear and the middle and low frequencies/basses are surprisingly very warm and full. I have the system EQ in the PC set on, what you could call, ROCK.
Not a bad pair for 25 pounds or so. The 100mm mid/low freq. speakers are just enough for use on your desk.  ____________________ '87 Honda XBR 500, '96 Kawasaki ZX7R P1, '90 Honda CB-1, '88 Kawasaki GPz550, MZ 150 ETZ
'95 Mercedes-Benz w202 C200 CGI, '98 Mercedes-Benz w210 E200 Kompressor |
| ferrisio |
 ferrisio Scooby Slapper
 Posted: 17:39 - 28 May 2015 Post subject: |
I'd be tempted by some active studio monitors, something like https://www.thomann.de/gb/alesis_elevate_5.htm for £100. Means you don't need a subwoofer, a lot of small speaker systems sound good but lose stereo image due to the crossover frequency to the sub being so high because of their small size. ____________________ BMW R1100R |
| Northern Monkey |
 Posted: 18:37 - 25 Jun 2015 Post subject: |
Looked at studio monitors, but too many ponds.
With a bit of buggering about, and rearranging, got some old Wharfdale speakers down from the loft, and bought myself a Cambridge Audio amp from richer sounds for £80
https://img.photobucket.com/albums/v284/geoffhill/IMG_7964_zps5zwtbdgh.jpg
Everything is now about eleventy times clearer than it was before.
Proper hifi, even cheap stuff, sounds like proper hifi. ____________________ Fisty: after polishing the tank with the glistenng beads of sweat from my full hot scrotum, I filled the headrace bearings with 10cc of my manmilk |
| Accuhaler |
 Accuhaler Nitrous Nuisance
| Dalemac |
 Dalemac World Chat Champion
| el_oso |
 el_oso World Chat Champion
| Northern Monkey |
| Howling TerrorOutOfOffice |
 Howling TerrorOutOfOffice Super Spammer
 Posted: 23:48 - 25 Jun 2015 Post subject: |
| Northern Monkey wrote: | Looked at studio monitors, but too many ponds.
Proper hifi, even cheap stuff, sounds like proper hifi. |
Miles better I imagine.
I have some 9.1 wharfedales and can't fault them when used in a small room. Check the 9.1s out if you fancy a slight upgrade.
Blu-tac under each corner of the speakers should give a clearer sound too, or if you can source some dense foam and cut them into wedges you can aim the tweeters at your ears and the dense sponge helps to decouple the speakers from the desk. Bestest and cheapest upgrade to any speaker. ____________________ Diabolical homemade music Bandcamp and Soundcloud
The Harry Turner Project |
| Northern Monkey |
 Posted: 10:38 - 26 Jun 2015 Post subject: |
Nice speakers with excellent reviews. If you don't already know rear ports won't like being close to walls/corners.
[edit] Their manual mentions using the supplied foam bungs....which I've never been a fan of. Kinda defeats the design and reduces the Bass performance IMO.
...Apologies if I'm going all audiogeek. ____________________ Diabolical homemade music Bandcamp and Soundcloud
| Northern Monkey |
| The Artist |
| Northern Monkey |
| The Artist |
 Posted: 18:24 - 26 Jun 2015 Post subject: |
Active monitors in the main get used in the studio because they tend to offer a relatively flat EQ and are easier to transport. They are not designed to flatter or enhance the sound unlike Hi-fi speakers. Some studio monitors can get quite tiring on the ears.
Just saying like.
There are no real rules but the guidelines could make your ear happier and save you money, especially if you audition say the Adam against some Dali. ____________________ Diabolical homemade music Bandcamp and Soundcloud
| ferrisio |
The last post was made 11 years, 67 days ago. Instead of replying here, would creating a new thread be more useful? |
