GSXR 600 Srad 1998 electrical fault
mmalik
PostPosted: 09:51 - 28 May 2015    Post subject: GSXR 600 Srad 1998 electrical fault Reply with quote
Hi all,
Hoping you can help get my bike back on the road. Some background first. Had an alarm on bike that I removed and soldered wires back together, that was 2 months ago. Bike running lovely since then. On my way home approx. 7 days ago, stopped at the junction, bike totally cut out, no electrics, thought it might be a loose connection, checked and nothing. Read some stuff online and most suggestions say rectifier. Took tail off and checked rectifier but all cables look fine, no burnt ones. Removed rectifier and still same problem.
Fully charged the battery, checked the main fuse too. There seems to be a lot of clicking sounds coming from the relay next to the rectifier.
Fully charged battery: 12.24v
Connected to bike but ignition off : 12.22v
Connected to bike ignition on: multi meter starts jumping around like crazy.
Panel lights not on or flickering on and off. Relay G8MS-S23 clicking away.
Have replaced relay but same problem, do not have spare battery to test with and do not know anyone around here with a bike.
All help/advice gratefully received.
Thanks in advance.
Mal
mmalik
PostPosted: 13:43 - 28 May 2015    Post subject: Reply with quote
Vincent wrote:
Any idea what the relay is for? Maybe a short somewhere connected to that??
Think it is the petrol pump. Replaced relay and still same fault. Need to locate a battery to test with but not sure where from Sad
orac
PostPosted: 16:43 - 28 May 2015    Post subject: Reply with quote
unplug pump, if the multi meter jumps about again then it not that
Tyron43 This post is not being displayed because it has a low rating (Spam). Unhide this post / all posts.
mmalik This post is not being displayed because it has a low rating (Spam). Unhide this post / all posts.
PostPosted: 10:27 - 02 Jun 2015    Post subject: Reply with quote
mmalik wrote:
30000 revs
QFT.
No, that's not right. You should be seeing something like 14V.
MaybeGuy
PostPosted: 10:29 - 02 Jun 2015    Post subject: Reply with quote
Check any fuses, but as it's dead completely though and not charging, chances are the generator is fried.
YA PLEZ
mmalik
PostPosted: 10:34 - 02 Jun 2015    Post subject: Reply with quote
lol typo with the revs..
Is there an idiot's "how to" for testing the r/r and Stator???
MaybeGuy
PostPosted: 13:26 - 02 Jun 2015    Post subject: Reply with quote
just start the bike and see if there's any power coming from the generator.
mmalik
PostPosted: 13:30 - 02 Jun 2015    Post subject: Reply with quote
will give it a go after work and see what happens...cheers
mmalik
PostPosted: 09:51 - 03 Jun 2015    Post subject: Reply with quote
Ok here goes, if I used the multi meter correctly then I got the following results:
Stator wires: I got approx. 60v from each of the wires.
R/R wires: I got a range from 0.350 to 0.360 and then when I crossed the multi meter probes over I got no reading.
I saw no burnt wires or melted connectors.
Not 100% sure that I am doing it correctly but watched a couple of youtube videos and copied them.
The last post was made 11 years, 97 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.35 - MySQL Queries: 13 - Page Size: 78.18 Kb
