Yep, another ER5 that won't fire
Spamalittle
PostPosted: 09:27 - 29 May 2015    Post subject: Yep, another ER5 that won't fire Reply with quote
Anybody got an idea of where to start diagnosing a 2001 ER5 that's turning over at a decent clip but won't fire?
Struggled to get the OH's ER5 fired up last week but after some perseverance it did eventually go. Tried again this morning and it's just a no go. Not even a cough.
I'm thinking it's either a fuelling issue - carbs needing a good clean maybe? Or could it be the starter motor?
New battery and plugs in it so I know they're okay.
I'm pretty new to the DIY mechanic bit so any thoughts much appreciated.
Also, whilst I'm here - at what point should you stop turning it over for fear of flooding the engine?
Story so far: RV125 VanVan > SV650 > Indian Scout > Triumph Thruxton, SV650 (again) & CG125
mudcow007
PostPosted: 09:49 - 29 May 2015    Post subject: Reply with quote
when your trying to start it are you cracking the throttle open?
Spamalittle
PostPosted: 11:09 - 29 May 2015    Post subject: Reply with quote
Yes, full choke and about half to two thirds throttle...
UncleFester
PostPosted: 11:46 - 29 May 2015    Post subject: Reply with quote
Sure the leads are on the plugs properly? And if there is a fuel tap ... are you sure it's not been flicked to reserve / off?
2017 Z1000SX
PostPosted: 12:40 - 29 May 2015    Post subject: Reply with quote
Why?
I know it depends on the bike, but my principle is that if it'll idle without throttle then it should fire up without it as well.
I never opened the throttle when starting my GPZ, for example, and my Enfield will kick back if the merest hint of throttle is applied while starting.
Spamalittle
PostPosted: 13:20 - 29 May 2015    Post subject: Reply with quote
Rogerborg wrote:
Why?
I agree that it shouldn't be necessary but she's a grumbly old girl who requires a loving kick augmented by a touch of voodoo to get her to wake up in the morning (much like me). Does struggle to idle w/o throttle for the first minute or so - even at full choke.
Tap definitely on run. Will give the leads a clean and wiggle after work and look at the carbs over the weekend I guess.
Monkeywrenche...
PostPosted: 17:32 - 29 May 2015    Post subject: Reply with quote
Start at the start.... Have a good go at starting it, then whip out a spark plug, or both. Is it covered in petrol or bone dry.
If its dry you have a fuel problem... wet its probably spark related.
that's a better place to start diagnosing the problem from.
If the starter is turning the engine over (you say it is at "a good clip") there's not a fault with it.
The last post was made 11 years, 106 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.76 - MySQL Queries: 13 - Page Size: 52.32 Kb
