| billybaggins |
 billybaggins Renault 5 Driver
| wristjob |
 wristjob World Chat Champion
| jimspeed |
 jimspeed World Chat Champion
 Posted: 23:36 - 28 May 2015 Post subject: |
it could be a few bits as said above, first check is how much free play in the cable, adjust the span on the lever to #1 to get max pull and i think there should be 3mm of free play at the lever where the cable joins.
otherwise it could be a warped plate or even a drive plate breaking up, worn clutch basket is a possible with that mileage too, either way its an easy enough job to do but get yourself a new clutch cover gasket before you take it off as it will break  ____________________ Hyosung cruise 125(passed test on, sold) Kawasaki el 252 (better than expected but sold on) Kawasaki GPZ500S first "big"bike.(sold) ZZR600 E5..Z750 2007,ER5, currently on a 2008 Enfield bullet electra x and loving it..
,"Alpha-9: Is there any correlation between dyno rod and dyno kits?" |
| Casper |
 Casper World Chat Champion
| billybaggins |
| DrSnoosnoo |
 DrSnoosnoo World Chat Champion
| Vincent |
 Vincent Banned
| Nobby the Bastard |
| johnsmith222 |
 johnsmith222 World Chat Champion
 Posted: 21:53 - 29 May 2015 Post subject: |
Remove your clutch actuator rod and inspect it, as this could very likely be the cause.
https://i14.photobucket.com/albums/a324/david_m213/DSC00370.jpg
It's the rod which the clutch cable is attached to in this picture, and goes through the hole in the clutch case.
I'm betting this is the problem if you've tightening your clutch cable hasn't sorted it. |
| billybaggins |
| billybaggins |
| johnsmith222 |
| billybaggins |
The last post was made 11 years, 104 days ago. Instead of replying here, would creating a new thread be more useful? |
