Drops power then cuts out (Usually)
jtclark93
PostPosted: 00:30 - 31 May 2015    Post subject: Drops power then cuts out (Usually) Reply with quote
So my NSR 125 was running very rough, sorted that with new oil, air filter, carb clean and spark plug.
Now i have recruited a new issue, the bike will idle perfectly fine, and for the first set off from stand still will do fine, and whilst ever the revs are on (even slightly) is fine, but as soon as i come off the revs to come to a stop, it loses power and wont even rev past 2.5k without making this dull BRRR sound and cutting out, will start up again fine, but repeats the same cruddy noise and low revs.
My first thought is that maybe the throttle cable is to blame (Not closing off properly) but that doesn't readily seem apparent.
Anyone care to take a stab at it?
hmmmnz
PostPosted: 09:36 - 31 May 2015    Post subject: Reply with quote
powervalve servo cables
or powervalve gummed up.
i assume these have powervalves Smile
the humans are dead
I kick arse for the lord
Taught2BCauti...
PostPosted: 09:53 - 31 May 2015    Post subject: Reply with quote
They have 'RC Valves' which are marked as such, and are the same as power valves.
It should start opening at 3,000 rpm and be fully open at 8,000 rpm, but have you also checked the carb?
Other possibility - a botched de-restriction attempt, so air leaking in, between the carb and the engine.
Honda Varadero XL125(V8)
www.TheFutureIsHere.eu
The last post was made 11 years, 102 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.87 - MySQL Queries: 13 - Page Size: 36.48 Kb
