| ScottT |
 ScottT Scooby Slapper
| unitynotsocri... |
 unitynotsocri... Banned
 Posted: 11:43 - 01 Jun 2015 Post subject: |
Maybe not. First and second are easy gears , even for a worn smoker stroker.
It may have to rev more for the same power if the piston,rings or crankcase seals are slightly feiuked.
Putting it in third and higher needs lots more lower down torque.....
If its smokey...ier...then check the compression.
I would check the lube system , a gummed up oil pump could cause havoc and I'd make sure the tanks clean and jets blown through
Lovely bike! ____________________ nearly a normal tax paying tosser.......with ferrileness suzi100,cg125,cb125scb100n,cb175,cd100,cj250t,kh250,c15,125 bantam,super 6,rickman gs750,xt500,250rs,dt175,lifan125,dolomite1850,metro,Morris220ld,morrisfg,leyland princess,range rover,corsa,vw camper .now struggling with legs. MORE ORDER = MORE CHAOS |
| unitynotsocri... |
 Posted: 11:44 - 01 Jun 2015 Post subject: |
Golly soz......forgot...I'm getting old....
Check the points if its not cdi. ____________________ nearly a normal tax paying tosser.......with ferrileness suzi100,cg125,cb125scb100n,cb175,cd100,cj250t,kh250,c15,125 bantam,super 6,rickman gs750,xt500,250rs,dt175,lifan125,dolomite1850,metro,Morris220ld,morrisfg,leyland princess,range rover,corsa,vw camper .now struggling with legs. MORE ORDER = MORE CHAOS |
| Vincent |
 Vincent Banned
The last post was made 11 years, 97 days ago. Instead of replying here, would creating a new thread be more useful? |
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.42 - MySQL Queries: 13 - Page Size: 41.4 Kb
