easiest way to put cylinder over piston?
PostPosted: 18:58 - 01 Jun 2015    Post subject: Reply with quote
Compressors:
https://www.youtube.com/watch?v=VISqGGMcBTc
https://www.youtube.com/watch?v=D3N8hzH0PKI
andys675
PostPosted: 19:00 - 01 Jun 2015    Post subject: Reply with quote
fit piston to rod, hold rings tight between thumb and forefinger on the sides of the piston, make sure barrel comes down squarely onto it and your fingers holding the rings are in the cutaways of the liner when you lower the barrel
or, fit piston in barrel with circlip in other side and gudgeon pin sticking out enough to lower over small end of rod, stick a rag all around the conrod, with small end bearing fitted lower it all down until you can get the gudgeon pin through the small end bearing, now all you have to do is fit last circlip and remove the rag
CaNsA
PostPosted: 19:17 - 01 Jun 2015    Post subject: Re: easiest way to put cylinder over piston? Reply with quote
<lihp>Get someone else to do it</lihp>
PostPosted: 19:23 - 01 Jun 2015    Post subject: Re: easiest way to put cylinder over piston? Reply with quote
Greaseproof paper or
bypass2
PostPosted: 21:01 - 01 Jun 2015    Post subject: Reply with quote
I always put a bit of two stroke oil around the bore then on the piston and the rings hold the rings tight with the thumb forefinger in the groves on the piston then slide the barrell over until you clear the top bottom rings.
jimspeed
PostPosted: 11:47 - 02 Jun 2015    Post subject: Reply with quote
Cable tie around the rings to hold them in and cut it off once the Harrell has pushed it off the piston ?
Hyosung cruise 125(passed test on, sold) Kawasaki el 252 (better than expected but sold on) Kawasaki GPZ500S first "big"bike.(sold) ZZR600 E5..Z750 2007,ER5, currently on a 2008 Enfield bullet electra x and loving it..
,"Alpha-9: Is there any correlation between dyno rod and dyno kits?"
The last post was made 11 years, 97 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.36 - MySQL Queries: 13 - Page Size: 62.02 Kb
