rxs rough running with air filter
SQL
PostPosted: 21:49 - 03 Jun 2015    Post subject: Reply with quote
Did you oil it?
trisers
PostPosted: 02:12 - 04 Jun 2015    Post subject: Reply with quote
Did the foam block the air inlet into the airbox at all? It needs a completely free flow into the airbox before the air passes through the foam filter inside.
And yes, it does need oiling so the dirt sticks to it rather than working its way right through the foam...still...better to have foam than no foam!
Taught2BCauti...
PostPosted: 09:04 - 04 Jun 2015    Post subject: Reply with quote
Sounds like a previous owner removed the stock filter and had to make some adjustments to the carb to get it to run properly.
Putting a filter (any type of filter) back in has upset the fine balance between fuel and air, so more adjustments are needed.
Check that the carb is the right one and all the jet sizes are standard - if so, adjustment should get you running right - if not, you will have to decide whether to replace jets, get a standard carb, or experiment with different types of filter material.
I have had some success building custom filters, using vacuum cleaner bags, cooker hood filters, and fibreglass matting used for bodywork repairs. Expanded aluminium mesh (also used for bodywork repairs) can be used for support, to stop filter material being sucked into the engine.
Honda Varadero XL125(V8)
www.TheFutureIsHere.eu
The last post was made 11 years, 118 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 1.67 - MySQL Queries: 13 - Page Size: 137.02 Kb
