| Pol Anorl |
 Pol Anorl Banned
 Posted: 21:31 - 03 Jun 2015 Post subject: rxs rough running with air filter |
opened air box to clean filter to see there was none, took the foam that sits between the 2 sections of my socket set and jammed it in there to give some protection from crap and it run like utter shit, took cover off and it run better took filter out and it was perfect....
what do?
standard jets
standard carb
middle setting on needle. ____________________ GOOD GAME BODYGUARD: https://i.imgur.com/8WePGgf.jpg
20:30:37 Pyro.: I don't sort of like men, I take every advantage to choke on dick.
Jewlio Iglesias: You live in Liverpool - Chances are, the front door has already been kicked off the hinges |
| SQL |
 SQL World Chat Champion
| Pol Anorl |
 Pol Anorl Banned
 Posted: 21:52 - 03 Jun 2015 Post subject: |
oil wut?
it wasnt an over time thing, the foam was just chucked in temporarily as id just cleaned the carbs it was a massive difference with and without, without i could redline with it in i could open it to wot and id have to wait for it to get there spluttering like mad. ____________________ GOOD GAME BODYGUARD: https://i.imgur.com/8WePGgf.jpg
| Vincent |
 Vincent Banned
 Posted: 22:04 - 03 Jun 2015 Post subject: |
Some air filters don't just clean the air, they direct airflow...esp on Yamaha 2 strokes. I'd stick a new OEM element in before looking elsewhere.
..and, it may run fast without the air filter, but it probably won't be long before it self destructs
Is the exhaust OK? ____________________ Space Is Deep |
| Pol Anorl |
 Pol Anorl Banned
 Posted: 22:29 - 03 Jun 2015 Post subject: |
standard filter is just a sheet of foam so no direction.
exhaust is fine no blockages or anything wrong with it no leaks. ____________________ GOOD GAME BODYGUARD: https://i.imgur.com/8WePGgf.jpg
| Vincent |
 Vincent Banned
| Pol Anorl |
 Pol Anorl Banned
 Posted: 01:15 - 04 Jun 2015 Post subject: |
has pretty big holes in it and didnt take up much room, it was a massive improvement without it even without the airbox cover it run brilliantly which shows something is wrong, any other type of filter would allow less air making it run rough again ____________________ GOOD GAME BODYGUARD: https://i.imgur.com/8WePGgf.jpg
| trisers |
 trisers Scooby Slapper
| Pol Anorl |
 Pol Anorl Banned
 Posted: 03:41 - 04 Jun 2015 Post subject: |
sensing lack of understanding...
i wont be using it without a filter once its sorted but it is running like shite with a random piece of foam that is less restrictive than a real filter would be so an oem filter it would run worse.
oil or no oil is irrelevant at the moment as it would infact reduce the airflow making it worse than it is now which is what i need to fix ____________________ GOOD GAME BODYGUARD: https://i.imgur.com/8WePGgf.jpg
| Taught2BCauti... |
 Posted: 09:04 - 04 Jun 2015 Post subject: |
Sounds like a previous owner removed the stock filter and had to make some adjustments to the carb to get it to run properly.
Putting a filter (any type of filter) back in has upset the fine balance between fuel and air, so more adjustments are needed.
Check that the carb is the right one and all the jet sizes are standard - if so, adjustment should get you running right - if not, you will have to decide whether to replace jets, get a standard carb, or experiment with different types of filter material.
I have had some success building custom filters, using vacuum cleaner bags, cooker hood filters, and fibreglass matting used for bodywork repairs. Expanded aluminium mesh (also used for bodywork repairs) can be used for support, to stop filter material being sucked into the engine. ____________________ Honda Varadero XL125(V8)
www.TheFutureIsHere.eu |
 - Super Spammer
| Pol Anorl |
 Pol Anorl Banned
 Posted: 12:20 - 04 Jun 2015 Post subject: |
standard jets, when i took carb apart and overhauled it the c clip was on the lowest setting so it was eating fuel but now ive moved it to the middle its still running fine.
whats standard on air screw any ideas? all the way in 2 and a half out? ____________________ GOOD GAME BODYGUARD: https://i.imgur.com/8WePGgf.jpg
| Vincent |
 Vincent Banned
| Pol Anorl |
 Pol Anorl Banned
 Posted: 15:15 - 04 Jun 2015 Post subject: |
the airbox is a big box that runs paralel to the bike, the inlet is on the left side of the bike the outlet is on the right side at the front of the box, the foam filter sits against the inlet side.
like so
https://i.imgur.com/bLMJhO0.png ____________________ GOOD GAME BODYGUARD: https://i.imgur.com/8WePGgf.jpg
| Vincent |
 Vincent Banned
| Pol Anorl |
 Pol Anorl Banned
 Posted: 17:16 - 04 Jun 2015 Post subject: |
yep had carbs apart all cleaned rebuilt, correct size jets no washers missing nothing appears to be wrong.
getting enough fuel just seems strangled of air. ____________________ GOOD GAME BODYGUARD: https://i.imgur.com/8WePGgf.jpg
| Vincent |
 Vincent Banned
| Pol Anorl |
 Pol Anorl Banned
 Posted: 21:13 - 04 Jun 2015 Post subject: |
chokes fine as i say, carb was fully stripped everything that could be taken off was. ____________________ GOOD GAME BODYGUARD: https://i.imgur.com/8WePGgf.jpg
 - Super Spammer
| Vincent |
 Vincent Banned
| Pol Anorl |
 Pol Anorl Banned
 Posted: 01:58 - 05 Jun 2015 Post subject: |
reeds are fine, no air leaks, its really weird it should run like shit as it is without a filter but it runs better ____________________ GOOD GAME BODYGUARD: https://i.imgur.com/8WePGgf.jpg
| Vincent |
 Vincent Banned
| Pol Anorl |
 Pol Anorl Banned
 Posted: 12:41 - 05 Jun 2015 Post subject: |
jets are all fine, i didn't lift the needle i lowered it as the c clip was on the bottom of the needle i put it back to factory.
without a filter it runs fine revs correctly idles correctly and revs drop back down fine.
with a filter it hesitates big time idles up an down and revs hang ____________________ GOOD GAME BODYGUARD: https://i.imgur.com/8WePGgf.jpg
| Vincent |
 Vincent Banned
| Pol Anorl |
 Pol Anorl Banned
 Posted: 18:23 - 05 Jun 2015 Post subject: |
it only fits one way ____________________ GOOD GAME BODYGUARD: https://i.imgur.com/8WePGgf.jpg
The last post was made 11 years, 119 days ago. Instead of replying here, would creating a new thread be more useful? |
