tappet info please help?
eddie011
PostPosted: 12:23 - 03 Jun 2015    Post subject: tappet info please help? Reply with quote
Ok so im looking for info on a morini fm125-4t6m engine 4 stroke 125cc engine but no look finding a workshop manual can anyone please help with valve clearances
KnuckleShot
PostPosted: 13:01 - 03 Jun 2015    Post subject: Reply with quote
Try searching in youtube, might have a bit of luck there?
Taught2BCauti...
PostPosted: 09:10 - 04 Jun 2015    Post subject: Reply with quote
As a general rule-of-thumb when exact clearances are unknown and can't be found, I use 0.006" for the Inlet, and 0.008" for the exhaust, when the engine is hot.
Honda Varadero XL125(V8)
www.TheFutureIsHere.eu
Acerman This post is not being displayed because the poster is banned. Unhide this post / all posts.
Taught2BCauti...
PostPosted: 10:04 - 04 Jun 2015    Post subject: Reply with quote
Acerman wrote:
Valve clearence is to be done at cold engine!
...and checked when it is hot, so that if anything has expanded due to heat, a working clearance is maintained.
nowhere.elysium
The Pork Lord
PostPosted: 11:36 - 04 Jun 2015    Post subject: Reply with quote
Hot engine
You're an idiot.
lihp
PostPosted: 11:43 - 04 Jun 2015    Post subject: Reply with quote
Cold clearance specs are given and account for thermal expansion.
I agree with NE, you're an idiot.
Taught2BCauti...
PostPosted: 12:04 - 04 Jun 2015    Post subject: Reply with quote
Adjust when cold, check when hot.
This method is only ever used when the exact clearances aren't known and cannot be found, and is done to ensure that you have a safe working clearance when the engine is at normal operating temperature.
If you know what the clearances should be (and the OP doesn't), they are usually given for a cold engine, then obviously you work on a cold engine.
lihp
PostPosted: 12:07 - 04 Jun 2015    Post subject: Reply with quote
You're an idiot.
The last post was made 11 years, 100 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.79 - MySQL Queries: 13 - Page Size: 70.47 Kb
