| stranger12 |
 stranger12 World Chat Champion
| FuzzyBallz |
 FuzzyBallz Nova Slayer
| RhynoCZ |
 RhynoCZ Super Spammer
 Posted: 19:12 - 07 Jun 2015 Post subject: |
Well, the rings are gone, I guess. Any bits of metal in the exhaust system and/or oil? I'm not sure about '05 R6, but some of those eat their cylinders. 400ml is a lot.
Now, are you sure you know how to measure the oil level? If you were burning oil that quickly, there would be more signs around. The plugs would be black and shiny, there would be more of the blue smoke etc.
I'd also try to run an 10w40, instead of that racing 10w30 nonsense.  ____________________ '87 Honda XBR 500, '96 Kawasaki ZX7R P1, '90 Honda CB-1, '88 Kawasaki GPz550, MZ 150 ETZ
'95 Mercedes-Benz w202 C200 CGI, '98 Mercedes-Benz w210 E200 Kompressor |
| stranger12 |
| Andy_Pagin |
 Andy_Pagin World Chat Champion
| RhynoCZ |
| Nemo |
 Nemo Could Be A Chat Bot
| Pol Anorl |
 Pol Anorl Banned
 Posted: 20:25 - 07 Jun 2015 Post subject: |
arent r6s known for eating the sleeves? ____________________ GOOD GAME BODYGUARD: https://i.imgur.com/8WePGgf.jpg
20:30:37 Pyro.: I don't sort of like men, I take every advantage to choke on dick.
Jewlio Iglesias: You live in Liverpool - Chances are, the front door has already been kicked off the hinges |
| stranger12 |
| RhynoCZ |
 Posted: 21:02 - 07 Jun 2015 Post subject: |
My knowledge of the fuel injection systems is very limited, but if there's no O2 sensor, then the unit can't know how much of air is going through the exhaust/engine = the unit still runs like there was the factory fitted exhaust and air filter = making the mixture lean.
I'm quite sure you can change the fuel map, might gonna need a new control unit, since I doubt the OEM unit from the factory will allow you to do stuff with it.  ____________________ '87 Honda XBR 500, '96 Kawasaki ZX7R P1, '90 Honda CB-1, '88 Kawasaki GPz550, MZ 150 ETZ
| carlosvalderr... |
 carlosvalderr... Two Stroke Sniffer
| Acerman |
 Acerman Banned
| P.addy |
 P.addy Red Rocket
| blurredman |
 blurredman World Chat Champion
 Posted: 15:44 - 08 Jun 2015 Post subject: |
At only 13k and an R1. It's safe to say it's been ragged when cold, and taken to the limit many times. ____________________ CBT: 12/06/10, Theory: 22/09/10, Module 1: 09/11/10, Module 2: 19/01/11
Current: 1973 MZ ES250/2 - 18k, 1979 Suzuki TS185ER - 10k, 1981 Honda CX500B - 91k, 1987 MZ ETZ250 (295cc) - 40k, 1989 MZ ETZ251 - 52k. |
| stranger12 |
| RhynoCZ |
 Posted: 10:39 - 11 Jun 2015 Post subject: |
| RhynoCZ wrote: | Now, are you sure you know how to measure the oil level? If you were burning oil that quickly, there would be more signs around. The plugs would be black and shiny, there would be more of the blue smoke etc. |
Every single time, there is someone that can't measure the oil level and overfill the engine, claiming his motorcycle burns oil.
Right, no need to be warmed up, but let it sit for at least 5-10 minutes before you measure the oil level. If the engine was running right before the measuring, quite a considerable amount of oil will stay in the head and other parts of the engine = let it sit, till all come down to the pan.
If you read the manual or used the common sense, this would be the first thing, that you'd find out.
The blue smoke could be a plain condensation, caused by cold exhaust system and warm exhaust gases going through it. ____________________ '87 Honda XBR 500, '96 Kawasaki ZX7R P1, '90 Honda CB-1, '88 Kawasaki GPz550, MZ 150 ETZ
| stranger12 |
| RhynoCZ |
 Posted: 10:55 - 11 Jun 2015 Post subject: |
| stranger12 wrote: | So thing the idea of cold check is wrong . |
Well, no. Cold or hot, the only thing that matters is, that the oil gets down to the pan. The engine is even designed so 0.1L stays in the oil filter and then there's about 0.5L of oil, that stays somewhere in the engine. Possibly the head, oil cooler etc. The places it can't get down to the pan from, on it's own.
Admit it, you've made a mistake.
Think of it this way, you say the motorcycle was sat for 2 days, so that means two days ago you had a go on it, made the oil warm, after you turned the engine off, the warm oil, its viscosity is low due to heat, came all down the the pan. Now, where did the oil go from there? Cold or warm, the amount of oil is basically the same.
EDIT: Find the manual, fill up the engine with specified amount of oil. It's always wrong when you use the glass/dip stick to guess the right amount.
Also, if there is a number on the engine somewhere, telling you, for instance 3.6L, of oil, then you should know, that about 0.5L+0.1L in the filter, always stays in the engine, even when you drain it. - which is something that the manual also says.
The last thing is, always have the motorcycle on level place and balance it in the middle of its center of gravity, to get correct measurement. ____________________ '87 Honda XBR 500, '96 Kawasaki ZX7R P1, '90 Honda CB-1, '88 Kawasaki GPz550, MZ 150 ETZ
| Polarbear |
 Polarbear Super Spammer
| P.addy |
 P.addy Red Rocket
| stranger12 |
| carlosvalderr... |
| stranger12 |
The last post was made 11 years, 33 days ago. Instead of replying here, would creating a new thread be more useful? |
