Monkey bike electrics.
Marmalade
PostPosted: 18:55 - 22 Jun 2015    Post subject: Monkey bike electrics. Reply with quote
I've a dax copy and getting no charge into the battery.
It's a new stator fitted into a new stomp yx140, using standard stomp flywheel.
It has a regulator and the lights work when revved but no voltage change in the battery.
I would expect the white and yellow stator wires to be live when running but they show as neutral.
Could it be down to the flywheel, which I believe to be a lightened one?
Any suggestions?
bikenut
PostPosted: 14:52 - 23 Jun 2015    Post subject: electrics Reply with quote
pictures of flywheel insides, reg/rec wires and stator with wires may help.......how much air gap tween f/wheel magnets and stator poles??
nuts about bikes
Marmalade
PostPosted: 07:51 - 24 Jun 2015    Post subject: Reply with quote
It has the battery to charge. Runs lights, indicators etc.
when I was checking it the other day it was just at 11.7v, running or not.
The lights are powered direct from stator and are fine when you Rev it.
WD Forte
PostPosted: 11:37 - 24 Jun 2015    Post subject: Reply with quote
the diagram I have looks a similar arrangment as many small jap bikes
and shows a yellow for running lights and white for
charging the battery
the yellow will give AC from the stator direct to the lighting circuit
However, the white needs to be rectified and regulated before the battery to get a useful DC
Rectified to DC and regulated to keep the charging voltage within limits
Do you have a rectifier fitted and is the AC being rectified?
It isnt the flywheel or you'd get no output at all and no lights
My guess:
either a break in the wiring on that phase
or
it isnt gone through an RR
bikers smell of wee
bikenut
PostPosted: 11:56 - 24 Jun 2015    Post subject: electrics Reply with quote
pics to clarify might help.......
nuts about bikes
garth
PostPosted: 21:06 - 24 Jun 2015    Post subject: Reply with quote
Have you tried swapping the yellow and white wires over and checking?
mysterious_rider
PostPosted: 12:23 - 25 Jun 2015    Post subject: Reply with quote
Is it an inner rotor kit? Because they have no charging ability. Swap stator and flywheel to a standard 140. Be careful the 125 ones look very similar but are marginally different and will shred the woodruff key.
KAWASAKIIIII
Marmalade
PostPosted: 21:37 - 25 Jun 2015    Post subject: Reply with quote
I Have swapped the yellow and white while it was running, no difference.
It's an outer rotor.
I fitted a lighting stator when I fitted the engine, it wasn't charging so I fitted a 6 coil charging stator and it made no difference.
I'll sort pics.
WD Forte
PostPosted: 21:56 - 25 Jun 2015    Post subject: Reply with quote
rectumfrier
bikers smell of wee
Marmalade
PostPosted: 23:28 - 25 Jun 2015    Post subject: Reply with quote
WD Forte wrote:
rectumfrier
Unlikely. It was working all fine before i fitted the 140 engine.
This is the stator I've put on it, Looking through various sites leads me to say I need to get a suitable flywheel, finding what one is the harder bit.
https://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItemVersion&item=171788366876&view=all&tid=1404947531007
garth
PostPosted: 06:53 - 26 Jun 2015    Post subject: Reply with quote
Have you swapped from an electric start engine to the YX?
Marmalade
PostPosted: 00:18 - 27 Jun 2015    Post subject: Reply with quote
I have
garth
PostPosted: 08:17 - 27 Jun 2015    Post subject: Reply with quote
In which case you will need a different reg/rec off a non e/s c90.
Marmalade
PostPosted: 23:58 - 30 Jun 2015    Post subject: Reply with quote
Do you know what the difference is?
Marmalade
PostPosted: 14:42 - 03 Jul 2015    Post subject: Reply with quote
New rectifier arrived today.
Fitted it and it's exactly the same. Sad
Marmalade
PostPosted: 11:03 - 04 Jul 2015    Post subject: Reply with quote
I've got pics now.
The stator is 83mm, the id of the magneto is 86mm.
Ive checked the continuity of the earth, yellow and white wires, swapped the white and yellow around, checked voltages.
white and yellow voltages taken, they both have about 2v ac on tickover and one has about 6v and the other 15v when you rag the crap out of it.
The output voltage went up about 0.1v dc when ragging it.
Original reg/rec and link from hot output to battery.
https://i296.photobucket.com/albums/mm189/inspired5/monkey-dax/AB220964-EBA5-41F3-888D-C8091EE5EE91_zpswbyzj1hx.jpg~original
New stator numbers
https://i296.photobucket.com/albums/mm189/inspired5/monkey-dax/CF6B291D-4D7D-4C44-9EC2-23A8623226C5_zpszgbuqnqp.jpg~original
Wiring from stator to loom.
https://i296.photobucket.com/albums/mm189/inspired5/monkey-dax/FDF77CA2-32D6-45CC-BD1C-4020612E17F6_zpsailrwsoo.jpg~original
Flywheel numbers
https://i296.photobucket.com/albums/mm189/inspired5/monkey-dax/5F76045A-AF0B-4385-BE2F-D113C21BAEE4_zpspbxronxo.jpg~original
Outside of flywheel
https://i296.photobucket.com/albums/mm189/inspired5/monkey-dax/57BFE2AB-36B9-4BF8-90CE-E6CBB649F89B_zps2bii95wm.jpg~original
Inside flywheel
https://i296.photobucket.com/albums/mm189/inspired5/monkey-dax/F1BCB79D-C92B-4A47-8068-8E63F7F0F91E_zpsqkkrqhpf.jpg~original
Stator
https://i296.photobucket.com/albums/mm189/inspired5/monkey-dax/29D43B54-DE89-46AE-99E4-30BE0BDCEF66_zpsufkzilii.jpg~original
ignition out to cdi from stator
https://i296.photobucket.com/albums/mm189/inspired5/monkey-dax/2CDDF83F-7EE6-4B15-921A-B6BB55497E8C_zpseud9myi8.jpg~original
White and yellow to reg/rec wires on stator
https://i296.photobucket.com/albums/mm189/inspired5/monkey-dax/81B289D1-EB19-4797-9850-779DD9235E82_zpssdxhesr8.jpg~original
Earth and pulse from pickup
https://i296.photobucket.com/albums/mm189/inspired5/monkey-dax/46A7B032-79E9-44D6-BB43-2DD5F5341565_zpsvxkyi6ud.jpg~original
WD Forte
PostPosted: 13:45 - 04 Jul 2015    Post subject: Reply with quote
What's that scotchlok doing on there?
nasty things them is
Why is that extra red wire there?
That stator looks commonplace and
ignoring the other wires as it runs,
the usual configuration is
The white goes to the rectumfrier to be rectifed to DC for the battery
the yellow goes to the light switch (for lights obviously) and is tapped
in to the regulator too to keep the voltage within bounds.
To sum up
It runs and you have lights, but little or no charge voltage at battery
swapping W&Y and new RR makes no difference.
Its always hard to diagnose at a distance but I'd be investigating that scotchlok bodge first to see if its dragging the stator output down.
bikers smell of wee
Marmalade
PostPosted: 19:53 - 04 Jul 2015    Post subject: Reply with quote
I put the red one in as that is the live output that should charge the battery, done with a scotchloc so i can take it off.
with or without it, all voltages are the same
The last post was made 11 years, 86 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.77 - MySQL Queries: 13 - Page Size: 115.49 Kb
