| natefz6 |
 natefz6 Brolly Dolly
 Posted: 21:52 - 23 Jun 2015 Post subject: Fz6 S2 Fan problems |
Hi All,
So I have a new bike... YAY!! and I have a problem NO!!!
I got the bike of the father in law for a complete steal so I am not that disappointed and hopefully it should be an easy fix.
Basically during my commute yesterday I noticed after hooning it down the motorway when I hit town the temperature was shooting up sky high when stopping at lights and in slow moving traffic. It got to the point where the warning light came on just before I parked it up at work.. not good. It hit 125C at one point. So today on the way in I am thinking that maybe the fan is not kicking in, sure enough it wasn't. Anyway some googling revealed some common faults and remedies.
1, Fuse, I checked/tested that and it was fine.
2, Relay, swapped with the working headlight one of the same type no banana, headlights still work fan still didn't.
3, Fan motor, Lots of posts online seemed to suggest taking lots of things apart to test but some suggested going in to diag mode and selecting diag code 51. I did this and could hear the relay click but the fan was not turning. Giving it a jump start with my finger got it started and if I did this on the 1st cycle of the 5 tests it would continue to spin up for each next cycle with the momentum from the last.
So my question is. Is my assumption that the fan motor is screwed correct? or could it be there is not enough juice getting to it some how? The fan does sound a bit ropey when going so I think I am right but wanted to lean on the wisdom of "The Workshop" before parting with my hard earned.
Thanks for taking the time! ____________________ "no I didn't steal it that's just the way I ride" |
| natefz6 |
 Posted: 09:07 - 24 Jun 2015 Post subject: |
More to add..
On the way in to work this morning after the temp got to over 100c I gave the fan a spin to try and kick start it but had no joy.  ____________________ "no I didn't steal it that's just the way I ride" |
| c_dug |
 c_dug Super Spammer
| Baffler186 |
 Baffler186 World Chat Champion
 Posted: 09:46 - 24 Jun 2015 Post subject: |
go on here: https://www.600riders.com/forum/index.php there's probably a very detailed write-up. Most people on there have S2s as well.
Whilst you're at at, check (change) your coolant as well, which I know isn't the cause but if you still get problems it's one thing more to rule out. ____________________ Current: 2009 SV650 S, 1990 Kawasaki GT550
Previous: 2009 CBF125, 1998 GSF600, 2004 FZ6 Fazer, 1978 CB400a Hondamatic |
| natefz6 |
| Pol Anorl |
 Pol Anorl Banned
 Posted: 11:53 - 24 Jun 2015 Post subject: |
fans on the fazer never come on, mine was hot enough to cook a full roast on and it didnt come on, i think theyre set to like 120c...
just take the plug off the thermostat and run a wire from the plug for the fan and 1 to the thermostat to a switch then you can turn it on when you want which i do most days because why risk it over heating. ____________________ GOOD GAME BODYGUARD: https://i.imgur.com/8WePGgf.jpg
20:30:37 Pyro.: I don't sort of like men, I take every advantage to choke on dick.
Jewlio Iglesias: You live in Liverpool - Chances are, the front door has already been kicked off the hinges |
| Bikeless |
 Bikeless World Chat Champion
| natefz6 |
| Acerman |
 Acerman Banned
| Matt B |
 Matt B World Chat Champion
| natefz6 |
| natefz6 |
 Posted: 17:42 - 24 Jun 2015 Post subject: |
| Acerman |
 Acerman Banned
| Pol Anorl |
 Pol Anorl Banned
 Posted: 18:37 - 24 Jun 2015 Post subject: |
give the whole thing a good squirt of wd40 keep soaking it, it may be dry from being unused for so long... ____________________ GOOD GAME BODYGUARD: https://i.imgur.com/8WePGgf.jpg
| Val |
 Val World Chat Champion
 Posted: 20:06 - 27 Jun 2015 Post subject: |
Before you spalsh out hundreds remove the fan, disassemble the motor and clean it with good Halfords electric conatcts cleaner, also check the motor brushes - they cost few pounds. ____________________ Adrian Monk: Unless I'm wrong, which, you know, I'm not...
Yamaha Fazer FZS 600, MT09, XSR 900 |
| P.addy |
 P.addy Red Rocket
| natefz6 |
| Shinigami |
 Shinigami World Chat Champion
The last post was made 11 years, 115 days ago. Instead of replying here, would creating a new thread be more useful? |
