Timing chain broke on Keeway TX 125
TvrJohn
PostPosted: 12:54 - 24 Jun 2015    Post subject: Timing chain broke on Keeway TX 125 Reply with quote
Rang the dealer and they said scrap the engine, wasn't even interested in selling me a new chain !
whats that all about ?
NJD
PostPosted: 13:03 - 24 Jun 2015    Post subject: Reply with quote
using google wouldn't go a miss (if that's what you need).
When I walked into Kawasaki looking to get a Keeway RKV 125 ages ago the first they said was "we're actually doing away with the brand at the moment, but we can still order you one in" thank god for the declined finance otherwise that would of been a costly lesson.
Moral of the story.. don't know to much about the brand but would avoid (despite owning a chinese bike myself).
You do paint a very one sided "lets just bash the dealership" picture though, more information would be required before a name and shame was needed, although maybe he's just telling you how it is and being honest?
Just_James
PostPosted: 13:24 - 24 Jun 2015    Post subject: Reply with quote
The reason they've told you to scrap the engine and not sold you a timing chain is because the chain itself is likely to be the least of your concerns.
There is a very high chance of serious engine damage due to the snapped chain and very unlikely worth fixing on a cheap Chinese bike
Current Bikes / Projects: 1999 Rieju RS1 50
Previous bikes - 1986 DT125R (field bike), 1989 KX250, 1980 KX420 (with 500cc big bore), 1992 YZ250, 1988 KX500, 1989 XR250R, 1988 VFR400R NC24, 1999 Cagiva Mito 125, 2008 Rieju RS2 50 , 1993 Honda NSR 125
skatefreak
PostPosted: 14:01 - 24 Jun 2015    Post subject: Reply with quote
new engine time maybehaps?
-Jvr
misscrabstick
PostPosted: 14:52 - 24 Jun 2015    Post subject: Reply with quote
When a timing chain breaks, mostly things inside the engine that do not usually touch each other suddenly smash into each other with quite substantial force, this often causes valve, piston, cylinder head, valve gear, bore damage and a load of debris that can travel and wreck other parts too.
Scrap the engine is quite sensible advice generally.
Teflon-Mike
tl;dr
PostPosted: 16:43 - 24 Jun 2015    Post subject: Reply with quote
Err... timing chain? Term is usually used on Over-Head-Valve (OHV) push-rod engines that have chain driven cam; on Over-Head-Cam (OHC) engine's, usually called a 'cam-chain'.
Just had a quick look, to see if Keyway use the OHV CG engine, that has neither cam-chain nor timing chain, cam is gear driven off the crank, or the OHC engine, either Honda XL or Suzuki GS based.... even their own web-page is a bit coy, which would tend to suggest its an OHV CG lump.. which begs the question... are you sure it HAS a cam-chain to be broken?
Have you taken the rocker cover off or anything to have a look? what makes you think the cam-chain is snapped? COULD be something totally different...
Meanwhile, as said, if the cam-chain has snapped, what tends to happen is the crank-shaft caries on going round, driving the piston up and down, while the cam stops dead wherever it happens to be... usually opening a valve.. when there is most 'strain' on the cam-chain to make it snap... piston still traveling then comes up the bore and gives the half open valve a hefty smack, resulting in it bending... if you are lucky, the smack doesn't also crack the valve guide, though that can happen when you later try getting the bend valve out. Meanwhile, the snapped cam-chain will have dropped off the cam-sprockets and probably be wrapping itself around the crank sprocket; when it tangles enough, thats what will tend to make the crank stop rotating; but in the mean-time, its likely to get jammed up in stuff, chewed up and drop lots of shards of metal into the bowels of the engine.. it ENT pretty, really, it isn't.. it's a complete engine tear down job to sort out; not a quick or easy job, and likely to require quite a lot of more expensive parts over and above a new cam-chain, depending on what else has been damaged by the failure; cam-chain tensioner mechanism, crank-shaft bearings, piston, head, valves, rockers etc etc etc. Depending on how bad it is... it MIGHT still be cheaper to fix than buying a new engine..... but, probably not as cheap, and certainly not as easy as buying a second hand one......
IF.. diagnosis is correct to begin with.....
WD Forte
PostPosted: 17:00 - 24 Jun 2015    Post subject: Reply with quote
Yeah what TM said but
you're short on details and pics
Chinese cams chain are easily sourced and cheap
But
Are you sure its OHC?
If so, have you whipped the head and covers off and assessed the damage?
If not, do it then come back with better details.
You'll need more than a cam chain even if you're lucky and its repairable.
Just done a similar job on a Kymco 125 ( XL clone engine)
bikers smell of wee
PostPosted: 17:15 - 24 Jun 2015    Post subject: Reply with quote
How do you know that the timing chain has gone?
I mean, what are the symptoms, how have you diagnosed it, and what else has it taken out with it?
www.cmpo.co.uk don't list it, but are pretty good about coming up with appropriate parts.
TvrJohn
PostPosted: 22:54 - 24 Jun 2015    Post subject: Reply with quote
I have the cam chain in my hands
Shall take the head off, and report back
Can anyone identify the Keeway TX 125 OHC clone engine ? to source parts
thanks
TvrJohn
PostPosted: 12:44 - 26 Jun 2015    Post subject: Reply with quote
Ok head off, and the inlet valve has took a knock from the piston
Looks like Chinese Motorcycle Parts Online, have the new parts based upon engine model ref
PostPosted: 13:08 - 26 Jun 2015    Post subject: Reply with quote
Good on you for getting stuck in rather than binning it.
I guess that dealership can forget about getting any more business from you? Wink
WD Forte
PostPosted: 16:06 - 26 Jun 2015    Post subject: Reply with quote
has the chain actually snapped?
if so
did it snap cos it slipped and the piston hit a valve?
or did it suddenly snap all on its own causing the piston to
hit a valve?
Thinking about it
bikers smell of wee
TvrJohn
PostPosted: 11:34 - 29 Jun 2015    Post subject: Reply with quote
Yep cam chain snapped
When I put the cam in the head without the bearing cap section fitted, and turned it by hand it is stiff !
The cam runs in the al casting, normal, but it seems to of picked up on the alloy, a few score marks etc which has made it stiff to rotate.
Have checked the oil galleries in the camshaft and they seem ok
WD Forte
PostPosted: 12:23 - 29 Jun 2015    Post subject: Reply with quote
OK
On our Kymco the chain slipped and bent valves but
was pretty easy to sort out luckily
this place may help as well as CMPO
https://www.china-parts.co.uk/acatalog/Heads_Barrels.html
bikers smell of wee
The last post was made 11 years, 140 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.06 Sec - Server Load: 0.63 - MySQL Queries: 13 - Page Size: 88.83 Kb
