Exhaust leak
BrownTrousers
PostPosted: 15:46 - 27 Jun 2015    Post subject: Exhaust leak Reply with quote
Hi,
I installed a new slip on exhaust today but am noticing small air leaks around the joint of the header pipe to the slip on.
Nothing major (no noise or smoke clearly coming from there) but very noticeable puffing of air when I put my hand near it.
I was not meant to use the existing gasket and the fit seems nice and snug but no matter how tight I do up the clip, still some air leaks.
So, how can I fix this or am I just being paranoid - what are the potential consequences of leaving it?
If I decide not to just leave it then I'm.guessing I need some putty sealant stuff? Can anyone offer a link to recommended stuff?
Cheers.
Bikers make great organ donors - add your name to the register
Ducati Multistrada 950 | Triumph Tiger 800 XR | Honda CBR500R | Yamaha YBR 125 Custom
Itchy
PostPosted: 15:49 - 27 Jun 2015    Post subject: Reply with quote
Use some firegum or equivalent.
You can't just smear it on though as the gas will just blow it away.
You need to clamp it in place. So take off the exhaust plop some gum thinly on the inside. Put it back on the downpipe end. Then get an exhaust clamp line the inside with it then clamp it on the join.
In THEORY it is supposed to harden and cook and seal it up.
It worked on my first CBR6 when I used a slip on can and changed the can to a Scorpion can as the very slight hole was covered by the clamp.
It did now work for my SV or fazer though.
Acerman This post is not being displayed because the poster is banned. Unhide this post / all posts.
PostPosted: 16:12 - 27 Jun 2015    Post subject: Reply with quote
General purpose silicon sealant from your local supermarket or DIY place. Don't knock it unless you're tried it.
bugeye_bob
PostPosted: 16:17 - 27 Jun 2015    Post subject: Reply with quote
you may find it seals itself after a few rides and the carbon builds up.
BrownTrousers
PostPosted: 19:42 - 30 Jun 2015    Post subject: Reply with quote
Firegum purchased and applied liberally.
Motorbike now sounds like a motorbike rather than a sewing machine, and exhaust not blowing Thumbs Up Karma
PostPosted: 19:57 - 30 Jun 2015    Post subject: Reply with quote
When it hardens and crumbles, use the silicone sealant. Wink
wr6133
PostPosted: 20:01 - 30 Jun 2015    Post subject: Reply with quote
This
I did the gaps on my collector and the link pipe/end can join in Feb/March..... it's still there and not blowing.
I'd never buy firegum or the like again. It's great for a fortnight and then crumbles to dust.
The last post was made 11 years, 138 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.07 Sec - Server Load: 0.68 - MySQL Queries: 13 - Page Size: 61.85 Kb
