What cam chain splitter?
mysterious_rider
PostPosted: 15:10 - 28 Jun 2015    Post subject: What cam chain splitter? Reply with quote
Hey guys, bought a cheap cam chain splitter and it shredded threads straight away. Can you suggest a decent splitter and joiner that youve used for cam chains? I fear ill buy another but it will be meant for drive chains instead.
For 94' cb1000
Cheers.[/b]
KAWASAKIIIII
Val
PostPosted: 23:07 - 28 Jun 2015    Post subject: Reply with quote
You probably are not using the tool right.
In order to split the chain you need to grind off completely the pin heads first with a grinder or a dremel tool. If you use dremel you must use orange dremel bits they are the only ones that can grind steel:
https://www.ebay.co.uk/itm/201299630410?_trksid=p2057872.m2749.l2649&var=500493529495&ssPageName=STRK%3AMEBIDX%3AIT
Only after that use the chain breaking tool. Otherwise you will brake the tool no matter how expensive it is.
If you do it right you can split the chain with any even the cheapest tool like this one:
https://www.ebay.co.uk/itm/220962786642?_trksid=p2057872.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
Also note when you use the tool get some pipe to extend the tool handle and use some good long rachet wrench for the tool nut.
Carefully allign the tool and go forward and backwards few times when breaking the pin. You can use some WD40 too.
Again if you grind off the pin heads it will be easy.
You are changing the chain do you?
Also I have no idea what is your chain pins. Generally there are two types of pin heads - soft and hard ones.
For riveting the soft pin head ones you can use chain rivet tool type like this one:
https://www.demon-tweeks.co.uk/motorcycle/chain-tools/warrior-heavy-duty-chain-riveting-vice
For hard pin heads you need "Whale" type riveting tool, they are more hard to rivet:
https://www.ebay.co.uk/itm/Whale-Brand-Chain-Riveting-Tool-Fits-520-525-530-532-Pitch-Chains-/310845986596
You can call chain manufacturer and ask.
Finally:
Warning : DID do not recommend the cutting and Riveting of Cam Chain at home as incorrect fitment could result in engine seizure and resulting injury Rolling Eyes
Val
PostPosted: 23:16 - 28 Jun 2015    Post subject: Reply with quote
Vincent wrote:
Val wrote:
You are chaning the chain do you?
What's this Val ? Very Happy
S..its I mean typo happens Laughing
mysterious_rider
PostPosted: 06:37 - 30 Jun 2015    Post subject: Reply with quote
Yeh fitting new chain. Cheers for info. The prices... So far tensioner is 170 and i need all new guides too. Sad
KAWASAKIIIII
Acerman This post is not being displayed because the poster is banned. Unhide this post / all posts.
monkeybiker
PostPosted: 07:27 - 30 Jun 2015    Post subject: Reply with quote
Hooooow much Shocked
mysterious_rider
PostPosted: 11:19 - 30 Jun 2015    Post subject: Reply with quote
60k yeh needs two guides at 37 each. Tensioner and chain. Chain is 92 quid. Painful.
KAWASAKIIIII
Jefr0
PostPosted: 15:12 - 30 Jun 2015    Post subject: Reply with quote
Surprised you have to split the chain! On my CBR 600 I just had to take the cam chain sprockets off and drop the chain through the casings.
Try CMSNL for cheaper parts. I had to replace the cam chain sprockets, guides and cam chain, worked out a lot cheaper.
Rides: Honda XR 125 ('03) Honda CBR 600F ('91), Ducati 916 Biposto ('95)
Jefr0
PostPosted: 18:04 - 30 Jun 2015    Post subject: Reply with quote
Vincent wrote:
How do you get it off the crank?
Missed that bit. Remove the sprocket as below pic:
https://i.imgur.com/vo0bgIS.jpg
OP - sorry if not the same, just food for thought!
monkeybiker
PostPosted: 18:17 - 30 Jun 2015    Post subject: Reply with quote
I would have thought it could be removed without splitting it but didn't want to say and make meself look all silly like Very Happy
The last post was made 11 years, 138 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.07 Sec - Server Load: 0.41 - MySQL Queries: 13 - Page Size: 98.65 Kb
