Bandit died on me....
mudcow007
PostPosted: 11:18 - 30 Jun 2015    Post subject: Bandit died on me.... Reply with quote
So went for a quick blast on my motor-bicycle last night got about 10miles an it conked out
no lights/ ignition...nothing...nadda zip!
luckily was close to my brothers so dumped it there to attack tonight.
checked the kill switch, normal fuses under the seat but they were all cool
not even the ignition lights go on...
is there another by the fuse by the relays or anything?
my plan is to walk the beast back home tonight
Aff
PostPosted: 11:35 - 30 Jun 2015    Post subject: Reply with quote
Check the battery voltage.
Could be that your reg/reg or alternator failed and you ran out of electrickery.
Electric Bike Project
DrSnoosnoo
+1
mudcow007
PostPosted: 12:50 - 30 Jun 2015    Post subject: Reply with quote
dagnammit.....anyone know where the reg/rec is is on the old girl?
is it within the alternator?
PostPosted: 14:07 - 30 Jun 2015    Post subject: Reply with quote
You don't need to check the reg/rec yet. As said, check the battery voltage, but before you do that check the battery terminals where the leads connect, you can do this just by lifting the seat (and removing the battery shroud if it has one).
If you don't have a multimeter:
Check first the battery leads. If they are tight follow the red lead to the solenoid. On that solenoid you'll find a 30A fuse. Check the fuse. If it's ok and the other fuses are ok follow the black lead from the battery and find the end where it's fixed to the engine. Is it loose? If it's tight follow the skinny black lead that is spliced into that black one from the battery. It should go to a single spade connector. Wiggle that and see if you get any life out of it.
If everything listed above is ok then you probably have a dodgy ignition switch, by now you really need a multimeter.
mudcow007
PostPosted: 15:26 - 30 Jun 2015    Post subject: Reply with quote
Cheers Pete
will post my findings
on a side note, whats the furthest someone has pushed their bike back home from?
PostPosted: 15:53 - 30 Jun 2015    Post subject: Reply with quote
All the way....
PostPosted: 16:03 - 30 Jun 2015    Post subject: Reply with quote
mudcow007 wrote:
Cheers Pete
just under 1 mile, Blackbird, never again.
mudcow007
PostPosted: 20:57 - 30 Jun 2015    Post subject: Reply with quote
well 3 miles later in 28C sunshine, i got home a sweaty horrible mess
had to run up a hill, heart rate hit 170bpm Shocked
anyways....checked battery 12.6v
check fuse board - all good
take fairings off an check ignition fuse an its popped, replace with the spare one (by the solenoid) an boom i have ignition lights
now, what causes that little fella to pop?
PostPosted: 21:57 - 30 Jun 2015    Post subject: Reply with quote
If you put a spare 30A in place of a blown 10A you better swap it back quick. If there's a short in the loom you'll melt it into a soggy blob.
mudcow007
PostPosted: 08:39 - 01 Jul 2015    Post subject: Reply with quote
it already had a 30a in Shocked - an the spare 30 was locked an loaded
will be promptly changed to a 10a when i get home
so im guessing there is a short somewhere, i reckon i will check the headstock that looks a prime suspect
daz070
PostPosted: 15:32 - 02 Jul 2015    Post subject: Reply with quote
my starter relay fuse is 30a I think its the right size,
The last post was made 11 years, 81 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 0.49 - MySQL Queries: 13 - Page Size: 73.54 Kb
