| mudcow007 |
 mudcow007 World Chat Champion
| Aff |
 Aff World Chat Champion
| DrSnoosnoo |
 DrSnoosnoo World Chat Champion
| mudcow007 |
 Posted: 14:07 - 30 Jun 2015 Post subject: |
You don't need to check the reg/rec yet. As said, check the battery voltage, but before you do that check the battery terminals where the leads connect, you can do this just by lifting the seat (and removing the battery shroud if it has one).
If you don't have a multimeter:
Check first the battery leads. If they are tight follow the red lead to the solenoid. On that solenoid you'll find a 30A fuse. Check the fuse. If it's ok and the other fuses are ok follow the black lead from the battery and find the end where it's fixed to the engine. Is it loose? If it's tight follow the skinny black lead that is spliced into that black one from the battery. It should go to a single spade connector. Wiggle that and see if you get any life out of it.
If everything listed above is ok then you probably have a dodgy ignition switch, by now you really need a multimeter. ____________________ a.k.a 'Geri'
| mudcow007 |
| P.addy |
 P.addy Red Rocket
| mudcow007 |
 Posted: 20:57 - 30 Jun 2015 Post subject: |
well 3 miles later in 28C sunshine, i got home a sweaty horrible mess
had to run up a hill, heart rate hit 170bpm
anyways....checked battery 12.6v
check fuse board - all good
take fairings off an check ignition fuse an its popped, replace with the spare one (by the solenoid) an boom i have ignition lights
now, what causes that little fella to pop? |
 Posted: 21:57 - 30 Jun 2015 Post subject: |
If you put a spare 30A in place of a blown 10A you better swap it back quick. If there's a short in the loom you'll melt it into a soggy blob. ____________________ a.k.a 'Geri'
| mudcow007 |
 Posted: 08:39 - 01 Jul 2015 Post subject: |
it already had a 30a in - an the spare 30 was locked an loaded
will be promptly changed to a 10a when i get home
so im guessing there is a short somewhere, i reckon i will check the headstock that looks a prime suspect |
| daz070 |
 daz070 L Plate Warrior
The last post was made 11 years, 81 days ago. Instead of replying here, would creating a new thread be more useful? |
