Brand New CBF 125, rode 25 miles, now not starting.
jaseypiom
PostPosted: 21:23 - 01 Jul 2015    Post subject: Brand New CBF 125, rode 25 miles, now not starting. Reply with quote
Hi,
I just bought a brand new CBF 125cc, I rode it 25 miles home and then parked it up in the garden. Now it doesn't start, you can hear it trying but it is not firing, if I give it some gas it ticks over and then cuts out soon as the revs cut under 2000RPM.
Is this because of the heat today or do I need to take it back to shop, is it a serious fault.
Yorkshire Geek
PostPosted: 21:30 - 01 Jul 2015    Post subject: Reply with quote
Brand new bike won't start? I'd take it back.
johnnyarctic
PostPosted: 21:34 - 01 Jul 2015    Post subject: Reply with quote
how if it doesn't start.. Laughing
check all the obvious things first. like fuel
Current Ride: VFR750
-Monty-
PostPosted: 21:36 - 01 Jul 2015    Post subject: Reply with quote
As has been said; check obvious things but I personally wouldn't bother fiddling around with things or Honda could potentially fob you off saying "your home mechanics broke the bike, you now have no warrantee."
Present: [Kawasaki ZX7r][Suzuki DRZ 400s]
Past: [Honda PCX 125] [Yamaha RXS 100] [Honda CB 500] [Triumph Speed Four] [Honda ST1100 Pan European - Po-Po Edition]
bamt
PostPosted: 21:41 - 01 Jul 2015    Post subject: Reply with quote
If it doesn't start, you say "Mr Honda dealer, come and recover this broken bike you sold me". One day and 25 miles in, they shouldn't be arguing about that.
But check the obvious stuff (oil, petrol) and if it starts when cooler. Even if it does start and run when cool, I'd be calling your dealer and asking them to check it out in case it is symptomatic of something that is going to cause problems down the line.
wodge
PostPosted: 21:42 - 01 Jul 2015    Post subject: Reply with quote
Does it per chance have a fuel tap?? Many, many people have forgotten about the silly little fuel tap under the fuel tank. I guess your bike is fuel injected so not sure it has one, but it's worth a punt..
nolidge iz pouwur.
Yamaha RXS100 RS100
wodge
PostPosted: 21:43 - 01 Jul 2015    Post subject: Reply with quote
oops, double post, but it does have fuel in it doesn't it?
nolidge iz pouwur.
Yamaha RXS100 RS100
NJD
PostPosted: 21:48 - 01 Jul 2015    Post subject: Reply with quote
(1) Has the kill-switch been knocked accidentally?
(2) Have you read the start up procedure according to the user manual?
(3) What's happening when you press the starter button?
(4) Have you attempted to start it with the throttle wide open and the stater button?
(5) Sufficient engine oil?
(6) Sufficient petrol?
(7) Take the bike to an empty road, turn the ignition on, put the bike into 2nd gear and keep the clutch pulled in.. now run like hell and let the clutch out slowly..
Does it show any signs of life when the clutch is let out?
(8) Electrics working, indicators, brake lights, front light with ignition on?
(9) Does it have a sidestand switch to stop the bike form being started, if so (and the sidestand is up) is it shorting out?
mauzo
PostPosted: 22:12 - 01 Jul 2015    Post subject: Re: Brand New CBF 125, rode 25 miles, now not starting. Reply with quote
Does the CBF have a choke? If it runs when you give it some throttle that feels like having the choke on when you don't need it.
NJD
PostPosted: 22:16 - 01 Jul 2015    Post subject: Re: Brand New CBF 125, rode 25 miles, now not starting. Reply with quote
"doh".
What's the recommended idol speed in your user manual?
The above basically indicates that it's set to low and is therefore cutting out as the engine is cold and isn't able to stay at a constant speed to warm itself up.
I sense a few runs around the block + idol screw adjustment = running Thinking
PostPosted: 23:13 - 01 Jul 2015    Post subject: Reply with quote
They really don't seem to like hot weather.
See...
https://www.bikechatforums.com/viewtopic.php?t=304515
...and all the links therein, and many many more about CBF125s shitting the bed when it's hot.
But a brand new one? Should just run. Get on to Honda-san and don't be fobbed off with "just needs run in" or similar.
Nicey-nice to begin with, but if they give you any lip, invite them to either make it run or take it back as you'll be rejecting it as not fit for purpose, i.e. use in the precise country and climate and time of year when they sold it to you.
thx1138
PostPosted: 23:22 - 01 Jul 2015    Post subject: Reply with quote
today?
Facebook page for CBF125 owners, quite a few reports of the bikes not liking the hot weather, and not running right.
PostPosted: 07:57 - 02 Jul 2015    Post subject: Reply with quote
Will not be remembered fondly. I wonder if the CB125F will do any better.
RedPanda
PostPosted: 09:44 - 02 Jul 2015    Post subject: Reply with quote
Made in India yet can't withstand heat, how ironic. Looks like I sold mine at just the right time.
Sorry to hear this Jase, it must be a complete bummer after all the excitement of buying one.
CBF125 (2013) -> CBR600F (2001) -> 'Ninja' 300 (2014)
PostPosted: 10:57 - 02 Jul 2015    Post subject: Reply with quote
The Indian ones are all carbed and therefore presumably gravity fed, so no pump, TPS or any associated electronomics.
They briefly dallied with selling the FI version over there but it cost more and had no benefits (emissions, kittens) and nobody bought it.
Northern Monkey
PostPosted: 11:07 - 02 Jul 2015    Post subject: Reply with quote
MSX uses a similar fuel pump and is subject to a fuel pump recall. Related?
PostPosted: 11:45 - 02 Jul 2015    Post subject: Reply with quote
Very likely.
It's surprising that they've never done a proper recall on the CBF and seems rather shortsighted regarding tarnishing their marque. I guess their solution is to can it in favour of the CB125F and hope for better luck this time.
PostPosted: 11:47 - 02 Jul 2015    Post subject: Reply with quote
check fuel/tap. Do nothing else except pick up phone and ring your Honda dealer.
That's what you are paying all that money for, the security of Honda's warranty and back up. Otherwise you might as well have bought Chinese.
NJD
PostPosted: 11:53 - 02 Jul 2015    Post subject: Reply with quote
Spent ½ an hour attempting to cold start mine on the day of purchase after sitting for some hours, that was a fun process Rolling Eyes Laughing
(Meanwhile work colleagues sit in their cars on the car park watching me run around attempting to get it going).
OP thrown himself in a river with the bike, UPDATE?
ScaredyCat
PostPosted: 12:41 - 02 Jul 2015    Post subject: Re: Brand New CBF 125, rode 25 miles, now not starting. Reply with quote
jaseypiom wrote:
Hi,
If it's a brand new bike you should have HondaCare, they can recover it for you for free back to the dealer. You should have a HondaCare card with your paperwork. Get the dealer to fix it. Probably fuel pump..
Check there's actually petrol in it first though, you did that - right?
No fuel tap on the cbf...
Honda CBF125 ➝ NC700X
Honda CBF125 ↳ Speed Triple
CBFcarl
PostPosted: 12:48 - 02 Jul 2015    Post subject: Reply with quote
If it is brand new, did you take it easy?
Only reason I ask is my first scooter (new) - no-one warned me about bedding it in easy. I did a high speed on the way home. The next day, wouldnt start. Got the dealer to pick it up and take it in and it turns out that I had fubared the piston rings.
thx1138 wrote: Well if you had a car, I'd bet it would smell like urine had had drunken sex with vomit and made a poo baby.
Polarbear wrote: They are all old now. Probably had more abuse that a Rotherham schoolgirl.
Hellkat wrote: I want to know if Nigella smells of garlic, or just minge.
PostPosted: 12:54 - 02 Jul 2015    Post subject: Reply with quote
You lie, I read this one article this one time...
Moar details. Did you rag it from cold, did it heat-seize at any point, and they explain how moving the pistons up and down a bit more frequently than intended could wreck them in short order?
Northern Monkey
PostPosted: 13:17 - 02 Jul 2015    Post subject: Reply with quote
Honda SFX50 is a 2 stroke 'ped
CBFcarl
PostPosted: 13:25 - 02 Jul 2015    Post subject: Reply with quote
No lies, I'm very honest, me.
The bike was an Italjet Formula 50 (liquid cooled). No mention on bedding in, just "heres your keys, helmet, insurance details and gloves. See you".
I got lost coming out of Sheffield, and ended up on "The Parkway" which is a dual carriageway with NSL. I was doing an indicated 60-odd MPH (still dont know how) and got home. On the way home from work the next night, I just lost power about 3 miles from home.
Pushed it home (got harrassed by two different sets of police officers asking where I got it from) and spoke with the dealers who picked it up. Three or four days later, I get a call saying that I had split the piston rings and asking if I had been ragging it. No, I said. They said that they would replace all the damage under warranty this time, but not again. When I picked it up, I got told how to bed it in, and did.
The piece of shit still broke down any time there was wet on the road or even if someone looked at it in the wrong way.
CBFcarl
PostPosted: 13:31 - 02 Jul 2015    Post subject: Reply with quote
The SFX50 was bought, second hand from my cousin.
The last post was made 11 years, 120 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 0.62 - MySQL Queries: 13 - Page Size: 132.71 Kb
