Nightmare of a brake problem - FZ6 S2
Shinigami
PostPosted: 16:21 - 02 Jul 2015    Post subject: Nightmare of a brake problem - FZ6 S2 Reply with quote
So, for a while i've been having issues with my rear brake, it's basicly chewing through pads in less than 1000 miles and doing so at an odd angle and uneven, also seems to be sticking occaisionally.
Now i've replaced the rota & pads, completely cleaned the fuck out of the caliper and pins, both slide pins baby smooth with 1500 grit sand paper (were ever so slightly rough) and greased them up.
Piston is pretty much spotless, no corrosion on it at all, with the caliper out and lever pressed then released the piston looks to retract a little though i've no idea how much it should.
Brake fluid also changed and lines bled.
Problem is still persisting today, went to feel the rota temperature and was red hot after little use of the rear, on centre stand it's clear it's not released the pads as it barely moves when try to spin it by hand
Any ideas? Next step i'm going to replace the seals on the piston maybe?
The caliper is a single pot nissin caliper
Matt B
PostPosted: 16:46 - 02 Jul 2015    Post subject: Re: Nightmare of a brake problem - FZ6 S2 Reply with quote
Would lead me to believe that something has been bent and is no longer lined up properly.
You need to work out a way of getting a couple of straight edges against the disc and the caliper or the mounting points and see.
Shinigami
PostPosted: 16:49 - 02 Jul 2015    Post subject: Reply with quote
by occaisionally I don't mean in a single rotation, just on some days it seems to stick more than others, before I just changed the pads again most of the time it didn't feel like it was sticking at all but it must have to some extent to wear the pads so quickly..
Matt B
PostPosted: 16:53 - 02 Jul 2015    Post subject: Reply with quote
Have you stripped the caliper and removed the piston? Could be a mashed seal inside.
Shinigami
PostPosted: 16:59 - 02 Jul 2015    Post subject: Reply with quote
i did a when it first started sticking but didn't notice anything obvious, I will have another look this weekend as won't have time to pull it all off and bleed it etc until then
Copycat73
PostPosted: 17:06 - 02 Jul 2015    Post subject: Reply with quote
is there one of those spring steel anti rattle / hold the pads in the correct position things fitted to the caliper ..
so is it fitted correctly ..?
caveat emptor
PostPosted: 17:56 - 02 Jul 2015    Post subject: Reply with quote
Does the piston push back into the pot with finger pressure?
If not, replace the seals or at least get the fluid seal out and clean out the groove behind it. Although you might as well replace it if you're doing that.
Shinigami
PostPosted: 17:59 - 02 Jul 2015    Post subject: Reply with quote
There is, and i'm pretty sure it's in the right way....
Parson
PostPosted: 18:57 - 02 Jul 2015    Post subject: Reply with quote
Seals sounds like the only thing left.
What kind of grease did you use on the pistons? Some types of grease will damage the seals. I spoke to one of the mechanics the local Suzuki dealers, rubber grease only on brake pistons. He gave me a wee dab recently when I was having isssues, a very helpful fellow.
Then gsx650F - Now VFR800F
monkeybiker
PostPosted: 19:05 - 02 Jul 2015    Post subject: Reply with quote
Is the foot pedal stiff?
Shinigami
PostPosted: 19:11 - 02 Jul 2015    Post subject: Reply with quote
red rubber grease
The piston is pretty tough to push back in, takes both hands and most of my strength (though I am a weakling)
Pushes in easy with a g clamp
i'll order some seals and see how that goes before some more serious damage/death occurs
cheers folks
PostPosted: 19:53 - 02 Jul 2015    Post subject: Reply with quote
It really does need to go back in smoothly and easily. Your disc isn't going to exert that much pressure. I mean, unless it's warped which would be a different issue. Wink
Shinigami
PostPosted: 21:10 - 02 Jul 2015    Post subject: Reply with quote
new seals ordered Thumbs Up only £3 on wemoto so worth trying
https://radiomaxmusic2.files.wordpress.com/2014/02/seal.jpg
and I'll be riding the womans cbf125 into work until then Laughing Cool
Matt B
PostPosted: 10:46 - 03 Jul 2015    Post subject: Reply with quote
Exactly this Thumbs Up
Pistons (both front and rear) should move back into a caliper with sustained pressure from your thumb or fingers. If it needs a clamp then you have a problem.
Shinigami
PostPosted: 21:39 - 04 Jul 2015    Post subject: Reply with quote
so changed the seals but still happening. Still difficult to push the piston back in by hand again too...piston looks spotless though so no idea whats going on Sad if I push the caliper against the disk it pushes the piston back in enough to release the wheel again
anyone know any decent bike garages in manchester who know their shit with brakes?
PostPosted: 22:04 - 04 Jul 2015    Post subject: Reply with quote
When you do the seals you have to scrape all the crusty white oxide powder from the bottom of the seal groove or the new seals will grip the piston too tightly.
Shinigami
PostPosted: 22:08 - 04 Jul 2015    Post subject: Reply with quote
didnt avtually see/notice any, gave it a bit of a clean out but nothing was white in there for sure, all black
Shinigami
PostPosted: 22:24 - 04 Jul 2015    Post subject: Reply with quote
might have another go and give the grooves a scrape out to be sure before I take it somewhere
Val
PostPosted: 22:26 - 04 Jul 2015    Post subject: Reply with quote
You can post your calipers for professional rebuild:
https://www.powerhouseautomotive.co.uk/content/motorcycle-brakes/motorcycle-brake-caliper-refurbishment-service.php
Honestly I am not sure how good idea is to rebuild your caliper yourself.
I would not do that. What can go wrong... erm no brakes or even worst locking wheel on the motorway.
kramdra
PostPosted: 22:45 - 04 Jul 2015    Post subject: Reply with quote
If they are anodised callipers they will not have corrosion in the seal groves (but plenty of dirt, brake fluid residue)
Do not scrape them with anything metallic. Match sticks work well.
LongJohn22
PostPosted: 23:03 - 04 Jul 2015    Post subject: Reply with quote
Do not scrape them with anything ferrous. Match sticks work well.
Fixed. Brass wire brush in a Dremel is awesome.
PostPosted: 23:13 - 04 Jul 2015    Post subject: Reply with quote
Anodised calipers rot as well. It just takes longer.
Shinigami
PostPosted: 01:18 - 05 Jul 2015    Post subject: Reply with quote
I actually have exactly that Thumbs Up cordless too, will give that a go
kramdra
PostPosted: 10:28 - 05 Jul 2015    Post subject: Reply with quote
Only if the anodise gets scratched.. This will never normally happen.
Dirt does not easily stick to anodise, very easy to clean. I consider lack of anodised callipers/pistons a good reason not to buy a bike Thumbs Up
13 years, 60k miles, no sign of rot... Anodised pistons also perfect condition - like new, unscratched. I admit the outside, calliper body looks a bit shit..
Shinigami
PostPosted: 15:18 - 05 Jul 2015    Post subject: Reply with quote
Cleaned it out, seals sitting nicely flush, was able to push piston in by hand, pooped straight in all the way down once past the seals. Rebled and refitted.....
...still binding. What the fuck. I'm just gonna set the bike on fire instead I think
The last post was made 10 years, 363 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.14 Sec - Server Load: 1.46 - MySQL Queries: 13 - Page Size: 131.39 Kb
