| Shinigami |
 Shinigami World Chat Champion
 Posted: 16:21 - 02 Jul 2015 Post subject: Nightmare of a brake problem - FZ6 S2 |
So, for a while i've been having issues with my rear brake, it's basicly chewing through pads in less than 1000 miles and doing so at an odd angle and uneven, also seems to be sticking occaisionally.
Now i've replaced the rota & pads, completely cleaned the fuck out of the caliper and pins, both slide pins baby smooth with 1500 grit sand paper (were ever so slightly rough) and greased them up.
Piston is pretty much spotless, no corrosion on it at all, with the caliper out and lever pressed then released the piston looks to retract a little though i've no idea how much it should.
Brake fluid also changed and lines bled.
Problem is still persisting today, went to feel the rota temperature and was red hot after little use of the rear, on centre stand it's clear it's not released the pads as it barely moves when try to spin it by hand
Any ideas? Next step i'm going to replace the seals on the piston maybe?
The caliper is a single pot nissin caliper ____________________ Current: Honda City Fly CLR125 2003 Honda CB600F Hornet 2008 Yamaha FZ6 S2 + 1991 Kawasaki GPZ500
"Once you realize what a joke everything is, being the Comedian is the only thing that makes sense. |
| Matt B |
 Matt B World Chat Champion
| Shinigami |
| Matt B |
| Shinigami |
| Copycat73 |
 Copycat73 World Chat Champion
| Rogerborg |
 Rogerborg nimbA
 Posted: 17:56 - 02 Jul 2015 Post subject: |
Does the piston push back into the pot with finger pressure?
If not, replace the seals or at least get the fluid seal out and clean out the groove behind it. Although you might as well replace it if you're doing that. ____________________ Biking is 1/20th as dangerous as horse riding.
| Shinigami |
| Parson |
 Parson Trackday Trickster
| monkeybiker |
 monkeybiker World Chat Champion
| Shinigami |
| Rogerborg |
 Rogerborg nimbA
 Posted: 19:53 - 02 Jul 2015 Post subject: |
It really does need to go back in smoothly and easily. Your disc isn't going to exert that much pressure. I mean, unless it's warped which would be a different issue.  ____________________ Biking is 1/20th as dangerous as horse riding.
| Shinigami |
 Posted: 21:10 - 02 Jul 2015 Post subject: |
new seals ordered only £3 on wemoto so worth trying
https://radiomaxmusic2.files.wordpress.com/2014/02/seal.jpg
and I'll be riding the womans cbf125 into work until then  ____________________ Current: Honda City Fly CLR125 2003 Honda CB600F Hornet 2008 Yamaha FZ6 S2 + 1991 Kawasaki GPZ500
| Matt B |
| Shinigami |
 Posted: 21:39 - 04 Jul 2015 Post subject: |
so changed the seals but still happening. Still difficult to push the piston back in by hand again too...piston looks spotless though so no idea whats going on if I push the caliper against the disk it pushes the piston back in enough to release the wheel again
anyone know any decent bike garages in manchester who know their shit with brakes? ____________________ Current: Honda City Fly CLR125 2003 Honda CB600F Hornet 2008 Yamaha FZ6 S2 + 1991 Kawasaki GPZ500
 Posted: 22:04 - 04 Jul 2015 Post subject: |
When you do the seals you have to scrape all the crusty white oxide powder from the bottom of the seal groove or the new seals will grip the piston too tightly. ____________________ a.k.a 'Geri'
| Shinigami |
| Shinigami |
| Val |
 Val World Chat Champion
| kramdra |
 kramdra World Chat Champion
| LongJohn22 |
 LongJohn22 Trackday Trickster
 Posted: 23:13 - 04 Jul 2015 Post subject: |
Anodised calipers rot as well. It just takes longer. ____________________ a.k.a 'Geri'
| Shinigami |
| kramdra |
| Shinigami |
The last post was made 10 years, 364 days ago. Instead of replying here, would creating a new thread be more useful? |
