| vladthetodge |
 vladthetodge Two Stroke Sniffer
| bikenut |
 bikenut World Chat Champion
 Posted: 09:26 - 03 Jul 2015 Post subject: axle |
what bike is it??
you need an assistant but first when the axle nut is loose, do any of the wheel spacers turn on the axle meaning they are free and not seized to the axle.
also check brake back plate/caliper holder for the same reason.
when all these are known to be free, get your assistant to place a lump hammer against the swing arm as close as possible to the axle, on the side the axle comes out.
hold the lump hammer against the swing arm as tight as possible.
using a suitable size hammer and a brass drift, with the brass drift against the axle end, strike the drift with a good swinging blow, your arm forming an arc to gain the striking force. gravity and your arm weight/hammer weight forming the force.
did the lump hammer lift off the other end due to the shock or did the axle move slightly?
if it moved slightly, lub lub lub am tap the axle back in, then repeat, a bit by bit approach, be patient.
if no movement, then a bit more force.
don't forget to lub.
hopefully the axle is just stuck, and not well and truly corroded to the bearing inners and distance tube.
check with cmsnl to see if the bearings are held in with circlips....don't damage the hub.
steady as you go and report back. you have a heat gun or lone the girls hair drier..... ____________________ nuts about bikes |
| vladthetodge |
| Ste |
 Ste Not Work Safe
 Posted: 23:53 - 03 Jul 2015 Post subject: |
I had a problem similar to that a few years ago and the easiest solution was to cut the axle using a hacksaw.  |
| Raffles |
 Raffles World Chat Champion
| vladthetodge |
| Casper |
 Casper World Chat Champion
| kramdra |
 kramdra World Chat Champion
 Posted: 20:05 - 04 Jul 2015 Post subject: |
Had the same issue with my sinnis stealth, there was no lube on spindle It had to be hacksawed off on both sides, which was a horrible task. Clamped wheel down on work bench, and it took a lot of sledge hammer abuse to get the remains out. |
| vladthetodge |
| Casper |
| Acerman |
 Acerman Banned
| vladthetodge |
| Raffles |
| Casper |
| vladthetodge |
| vladthetodge |
| vladthetodge |
| Raffles |
| vladthetodge |
The last post was made 10 years, 266 days ago. Instead of replying here, would creating a new thread be more useful? |
