Will it scrub up? And Spindle bobbins?
Gazz
PostPosted: 18:39 - 07 Jul 2015    Post subject: Will it scrub up? And Spindle bobbins? Reply with quote
Thoughts and opinions on this guys... Will this chain and sprocket clean up?
It is actually a brand new chain that has only done about 10 miles or so, but has been sat at the back of a garage for about 2 years.
https://scontent-lhr3-1.xx.fbcdn.net/hphotos-xtf1/v/t1.0-9/11665731_10153395912772768_2423422821845675081_n.jpg?oh=530578deb39e69392458779ad5b45e15&oe=561F7303
A new chain is only £13 but I don't want to spend any unnecessary cash on the bike in case it fails an MOT so would have been £13 wasted if it fails on something else, but there is a possibility that it will fail for the chain if I don't get a new one and in which case I would loose money paying for an MOT retest (going on holiday so wont be able to get it in within the allotted retest time).
P.S. I like to things on a budget especially where this bike is concerned, so please when you answer, assume that £13 is actually a lot of money.
Also,
Is there such a thing as spindle bobbins? As you can see there is nowhere to use a stand on this bike and I have in the past used 2 axle stands under the swing arm to clean the chain, but looking for a more professional option since the bike sometimes slips off the stands if they are not lined up correctly.
Or if I have just invented a new product that hasnt been invented before, can someone suggest an alternative method to clean chains?
Hefty
PostPosted: 18:49 - 07 Jul 2015    Post subject: Reply with quote
Im gonna go out on a limb and say that chain will fail.
'13 Honda CBF125 // '99 Suzuki SV650s // '98 Honda CB600F Hornet
totalllama82
PostPosted: 19:24 - 07 Jul 2015    Post subject: Reply with quote
You'd need to remove that chain and soak it in oil. It may still move and the rust could be surface.
Personally i'd replace it and both sprockets as you're hard pushed to tell if the o rings (if it indeed has any) are in any sort of condition.
As for the stand, get a paddock stand with flat legs... something like this https://www.ebay.co.uk/itm/Warrior-Rear-Motorcycle-Bike-Paddock-Stand-Track-Day-Garage-Pit-/371169071935?pt=LH_DefaultDomain_3&hash=item566b66933f
Gone: Haotian HT125-8 / Yamaha YZF 600R Thundercat / Kawasaki ZX9R C2
Current: Kawasaki ZZR 1400 A7F
Gazz
PostPosted: 19:29 - 07 Jul 2015    Post subject: Reply with quote
totalllama82 wrote:
Got one of those, but the swing arm slips on that as well because the bike sits quite high and the angle is quite steep as a result.
chickenstrip
PostPosted: 19:31 - 07 Jul 2015    Post subject: Reply with quote
In my view, that chain has had it. Although knowing this place, someone will come along in a minute and tell me it can be made good as new Rolling Eyes
pepperami
PostPosted: 19:51 - 07 Jul 2015    Post subject: Reply with quote
I wouldn`t be to happy to use a bike with a chain in that state.
I would be inclined to put a new chain on and maybe? keep that one as a very emergency spare.
PostPosted: 20:01 - 07 Jul 2015    Post subject: Reply with quote
Rolling Eyes
Never post pictures of a slack chain on BCF.
What makes you think that the chain and sprockets won't clean up?
Fisty
PostPosted: 20:03 - 07 Jul 2015    Post subject: Reply with quote
Thirteen pounds for a new one.
Thirteen pounds.
Look at the old one. Look at it, then look again.
For thirteen English ponds, I would have that old one off and a new one on. It's fucked.
Just make sure the rest of the bike wont fail the MOT, it isn't rocket science.
You are Smiler and I claim my 5 ponds.
Fatter and faster than Fret
-Matt-
PostPosted: 20:30 - 07 Jul 2015    Post subject: Reply with quote
No idea if this is the cheapest place to buy it (or if you can just buy the bits to add to your current stand) - but this is the rear paddock stand i've got. I've since put hook-adaptors on mine, but the ones it comes with have a raised inner section which might stop it slipping?
https://www.fastbikebits.com/product/22/moto-gp-rear-paddock-stand?gclid=CIyG1qzgycYCFQLKtAodFA8Ckw
https://www.fastbikebits.com/shopimages/products/normal/MGPSTD02-rear.jpg
iooi
PostPosted: 21:38 - 07 Jul 2015    Post subject: Re: Will it scrub up? And Spindle bobbins? Reply with quote
Gazz wrote:
T in which case I would loose money paying for an MOT retest (going on holiday so wont be able to get it in within the allotted retest time).
So why not wait till after the holiday before getting it tested then......
Personally just wheel it down. Let them test it and see what they say it's failed on Laughing
Even a couple of tins of chain lube will be more than £13... But I just wonder what sort of chain you get for £13.00 Embarassed
Raffles
PostPosted: 23:00 - 07 Jul 2015    Post subject: Reply with quote
Attempting to cosmetically enhance that chain is going to take an eternity.
I once 'cleaned-up' a chain that wasn't half as bad as yours and I've vowed to never do it again.
Stop being a stereo-typical jock and buy a new one.
Thirteen ponds? Rolling Eyes
Matt B
PostPosted: 10:53 - 08 Jul 2015    Post subject: Reply with quote
So much potential fail in this Pass the popcorn
Spindle Bobbins - yes they exist but you would need a rear axle bolt with a hole right the way through to make it work. Or you can get some that clamp around the end of the swingarm.
https://www.satoracing.com/pics/CBR250RSpools2.jpg
However, if you are too tight to weigh out a paltry thirteen pounds on a chain then those will be out of budget.
chickenstrip
PostPosted: 11:00 - 08 Jul 2015    Post subject: Reply with quote
Got to be a bit worried about anyone who balks at spending such a small amount on such an essential item. What other corners will be cut? I think there are times when one just has to face the fact that they are not in a position to run any kind of motor vehicle.
TheSmiler
PostPosted: 11:28 - 08 Jul 2015    Post subject: Reply with quote
Hell no, even I wouldn't keep that on it, I'd replace it for £13 why risk riding with it. In that state it could easily fail; yes I've had chains in similar condition but I've now learnt my lesson.
pepperami
PostPosted: 20:02 - 08 Jul 2015    Post subject: Reply with quote
OP, the conclusion of this thread is : stop being tight and get a new chain.
Gazz
PostPosted: 20:48 - 08 Jul 2015    Post subject: Reply with quote
Ive bit the bullet and ordered up a shiny new £13 (which can be collected from Argos Confused ) as well as a new fuel filler cap too. This bike just doesn't know how good I am to it. Already bought it a new horn for £6 this week!
Will post back once it goes for its MOT.
Should I start a poll to see if it will fail or not?
1198
PostPosted: 21:16 - 08 Jul 2015    Post subject: Reply with quote
Just as a matter of interest what bike is this on? I'm only curious, I agree entirely with the feeling to ditch it and invest a massive £13 on reducing your chance of suffering a fatal case of deadness...
Gazz
PostPosted: 21:32 - 08 Jul 2015    Post subject: Reply with quote
Hyosung XRX125
Dave70
PostPosted: 23:50 - 08 Jul 2015    Post subject: Reply with quote
A bit of spit and polish should do the trick. Laughing
Seriously though, go and buy a new chain. Thumbs Up
Gazz
PostPosted: 19:23 - 09 Jul 2015    Post subject: Reply with quote
Just checked the price of that Shocked ! $120 (£78 before shipping).
Will have a look at making something similar when I get time. Cheers for the idea.
The last post was made 11 years, 61 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.68 - MySQL Queries: 13 - Page Size: 115.11 Kb
