| billybaggins |
 billybaggins Renault 5 Driver
| Pete. |
 Pete. Super Spammer
 Posted: 20:34 - 07 Jul 2015 Post subject: |
Yep, that'll do it. The energy to heat that up has to come from somewhere, and that's the same place as supplies charging power.
I would quite simply chop the connectors off and use a good quality chocolate-block connector to re-connect the genny to the reg/rec. ____________________ a.k.a 'Geri'
| Kickstart |
 Kickstart The Oracle
| Howling TerrorOutOfOffice |
 Howling TerrorOutOfOffice Super Spammer
 Posted: 20:44 - 07 Jul 2015 Post subject: |
Typical of a regulator/rectifier failure but the cause is not often found. Could be increased resistance caused by dirty connections....thin wires from the stator (alternator)...overheating of reg/rec often due to poor placement.
Whilst you're waiting for a replacement you can test the AC output of the stator to see whether that has caused the reg/rec failure ( You'll have to do a search for how many watts it puts out).
Check the main earth cable...removed clean and grease.
You can either get new connector blocks or go the crimping route. ____________________ Diabolical homemade music Bandcamp and Soundcloud
The Harry Turner Project |
| billybaggins |
 Posted: 21:12 - 07 Jul 2015 Post subject: |
| johnnyarctic |
 johnnyarctic Scooby Slapper
| billybaggins |
| Pete. |
 Pete. Super Spammer
 Posted: 21:21 - 07 Jul 2015 Post subject: |
Un-plug the stator and run the engine. Set your meter to AC and measure across all three pairings from the stator. As a rough guide you should have about 60-70v at about 4-5000rpm. If all three pair combinations give you the same as above then it's probably good.
Really though, that loom plug is already cooked, cut it off and join the looms, see what charging voltage you get with everything electrical running. ____________________ a.k.a 'Geri'
| billybaggins |
| Pete. |
 Pete. Super Spammer
The last post was made 11 years, 113 days ago. Instead of replying here, would creating a new thread be more useful? |
