Is this why my battery isn't charging
billybaggins
PostPosted: 20:26 - 07 Jul 2015    Post subject: Is this why my battery isn't charging Reply with quote
Long story short, ZZR600, got a bad misfire then bike cut when clutch pulled in. Wouldn't turn over, battery was dead. New battery in today, got her started, voltage at 4k revs is only 12.4V so im assuming the charging system isn't working. I pulled the plug in the photo of the regulator and if you see the top left is cooked, will this be my problem or would this not be enough to stop it charging?
Also what would have caused this and how do I replace it, 1 wire cut or get a whole new plug. Should i look at the other end of this near the alternator for the plug down there? Its a bollix to get at and is covered in the dry oil so i haven't managed to get it off yet.
PostPosted: 20:34 - 07 Jul 2015    Post subject: Reply with quote
Yep, that'll do it. The energy to heat that up has to come from somewhere, and that's the same place as supplies charging power.
I would quite simply chop the connectors off and use a good quality chocolate-block connector to re-connect the genny to the reg/rec.
PostPosted: 20:39 - 07 Jul 2015    Post subject: Reply with quote
Possible that a bad connection has melted it, possible that it was over charging and that melted it. So if you do fix it, check that it is charging normally (and not just pushing out a high voltage)
There are a few places around that can supply the original connectors, but generally they are hard to find.
K
PostPosted: 20:44 - 07 Jul 2015    Post subject: Reply with quote
Typical of a regulator/rectifier failure but the cause is not often found. Could be increased resistance caused by dirty connections....thin wires from the stator (alternator)...overheating of reg/rec often due to poor placement.
Whilst you're waiting for a replacement you can test the AC output of the stator to see whether that has caused the reg/rec failure ( You'll have to do a search for how many watts it puts out).
Check the main earth cable...removed clean and grease.
You can either get new connector blocks or go the crimping route.
billybaggins
PostPosted: 21:04 - 07 Jul 2015    Post subject: Reply with quote
I have checked for continuity accross the rectifier connections that that had plugged into. The meter stays at 1 (open circuit I think), am i testing that properly?
To check at the stator do i take the plug off down there or can I check at the rectifier end? And do i have to try and turn the bike over or will i start to test it?
PostPosted: 21:12 - 07 Jul 2015    Post subject: Reply with quote
Reg/rec check https://www.youtube.com/watch?v=F8EjV0IjW9Q
Stator test https://www.youtube.com/watch?v=I7jPnbCIhOk
johnnyarctic
PostPosted: 21:13 - 07 Jul 2015    Post subject: Reply with quote
https://www.electrosport.com/media/pdf/fault-finding-diagram.pdf
this helped me when i was having charging problems. In my case my stator was dead, as well as the r/r. that was the first time, second it was just the r/r.
Current Ride: VFR750
billybaggins
PostPosted: 21:17 - 07 Jul 2015    Post subject: Reply with quote
cheers fellas
PostPosted: 21:21 - 07 Jul 2015    Post subject: Reply with quote
Un-plug the stator and run the engine. Set your meter to AC and measure across all three pairings from the stator. As a rough guide you should have about 60-70v at about 4-5000rpm. If all three pair combinations give you the same as above then it's probably good.
Really though, that loom plug is already cooked, cut it off and join the looms, see what charging voltage you get with everything electrical running.
billybaggins
PostPosted: 22:05 - 07 Jul 2015    Post subject: Reply with quote
Will i just cut the whole block off instead of that 1 wire?
Will i join with a choc bloc and run new wire with individual spades to the rr? What cable should i use?
cheers
PostPosted: 22:12 - 07 Jul 2015    Post subject: Reply with quote
cheers
Aah, I didn't check all the pics, your loom plugs directly into the reg/rec.
Perhaps you can release the spade terminals out of the loom plug and dress them clean, pinch them up a bit to improve contact.
The last post was made 11 years, 115 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.18 Sec - Server Load: 1.09 - MySQL Queries: 13 - Page Size: 73.1 Kb
