Helicoil/Timesert Help needed.
Moo.
PostPosted: 20:57 - 07 Jul 2015    Post subject: Helicoil/Timesert Help needed. Reply with quote
So, bought a Suzuki DR600 and previously one of the exhaust studs had snapped and has been drilled out with a M7.5 drill bit. I want to fit a Helicoil in there, but unsure what size helicoil i need.. (Also need to find the right pitch for the exhaust stud..) Anyone know what size helicoil would fit?
Or, do i just tap the hole out to M8?
A2 Passed 18/6/10
Fisty
PostPosted: 21:02 - 07 Jul 2015    Post subject: Reply with quote
M8 tap stick an 8mm stud in it. Should be a 6.8mm hole but there should be enough meat there to get an exhaust stud to bite.
Fatter and faster than Fret
PostPosted: 21:18 - 07 Jul 2015    Post subject: Reply with quote
The tapping size for a M8 x 1.25 roll tap (a.k.a thread forming tap) is 7.5mm.
Buy a roll tap and put a full M8 thread in it.
https://www.guhring.com/documents/tech/charts/formtapdrill.pdf
This WON'T work if the hole has wandered off the stud and some of the steel stud is in the hole.
Moo.
PostPosted: 21:23 - 07 Jul 2015    Post subject: Reply with quote
Like this? https://www.ebay.co.uk/itm/F-choice-of-M2-5-M3-M3-5-M4-M5-M6-M7-M8-HSS-Quality-FLUTELESS-ROLL-forming-TAP-/181149978009?pt=LH_DefaultDomain_3&var=&hash=item2a2d614d99
The hole looks clean and straight, i stuck a 7.5mm drill bit into it and its solid.
A2 Passed 18/6/10
PostPosted: 21:36 - 07 Jul 2015    Post subject: Reply with quote
Yes, like that. M8 x 1.25. Use copious amounts of lube.
Will the M8 clear through the hole in the pipe clamp?
Moo.
PostPosted: 21:40 - 07 Jul 2015    Post subject: Reply with quote
The hole in the clamp has also been drilled to 7.5mm and theres still a fair bit of meat, so i'm guessing drilling it to 8mm will be painless..
A2 Passed 18/6/10
WD Forte
PostPosted: 21:47 - 07 Jul 2015    Post subject: Reply with quote
Noooo!
Dont drill it any more
It sounds ready for an 8mm tap as it is
I'd remove the clamp and downpipe first too
bikers smell of wee
Moo.
PostPosted: 21:50 - 07 Jul 2015    Post subject: Reply with quote
WD Forte wrote:
Noooo!
The whole engines coming apart Sad to get rid off all the gasket sealant used and put new gaskets on..
A2 Passed 18/6/10
PostPosted: 21:53 - 07 Jul 2015    Post subject: Reply with quote
Ok, probably why the hole is straight then Smile
Roll taps are unforgiving. They form the thread by moving the metal rather than removing it. They use a special high-pressure lube to keep the flanks of the tap from friction-welding to the metal. The best I can think of is to use EP90 oil (Extreme Pressure) as a tapping lubricant. If it starts creaking back out and add more oil.
PostPosted: 21:55 - 07 Jul 2015    Post subject: Reply with quote
WD Forte wrote:
Noooo!
The clamp need drilling for M8 clearance.
Moo.
PostPosted: 06:12 - 08 Jul 2015    Post subject: Reply with quote
Cheers Pete. I've got some EP90 gear oil I can use, I'm guessing it operates like a normal tap? But its going to be alot harder..
A2 Passed 18/6/10
davebike
PostPosted: 09:12 - 08 Jul 2015    Post subject: Reply with quote
Tapping size for M8 1.25 is 6.25 to 6.5mm 7mm is just about do able but 7.5 will give a rather loose thread but may get away with it I no go there
thread depth is 1/2 the pitch thread is on both sides so subtract Pitch from size add a bit for Clarence for tapping size
Dave
NC750Xdct + others at work !
davebike1@gmail.com
Raffles
PostPosted: 10:28 - 08 Jul 2015    Post subject: Reply with quote
Same but different!
Roll taps can form a thread in one single operation. It's not necessary to keep 'backing' the tap out to break off chips, as none are produced. It is, though, imperative that the tap is kept in line with the hole. Unlike a straight flute hand tap, if slightly crooked, it isn't able to carve it's way through.
Be very much careful. You wouldn't want to have to remove a snapped one.
Aff
PostPosted: 11:31 - 08 Jul 2015    Post subject: Reply with quote
Using a form tap seems like a bit of a faff.
I would just drill both the head and the clamp out to 8.3 and put an M8 Helicoil in there.
You need to drill the clearance anyway.
Electric Bike Project
PostPosted: 16:28 - 08 Jul 2015    Post subject: Reply with quote
Not for a roll tap it isn't...
The last post was made 10 years, 266 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.72 - MySQL Queries: 13 - Page Size: 88.59 Kb
