| Moo. |
 Moo. World Chat Champion
| Fisty |
 Fisty Super Spammer
| Pete. |
 Pete. Super Spammer
 Posted: 21:18 - 07 Jul 2015 Post subject: |
The tapping size for a M8 x 1.25 roll tap (a.k.a thread forming tap) is 7.5mm.
Buy a roll tap and put a full M8 thread in it.
https://www.guhring.com/documents/tech/charts/formtapdrill.pdf
This WON'T work if the hole has wandered off the stud and some of the steel stud is in the hole. ____________________ a.k.a 'Geri'
| Moo. |
 Posted: 21:23 - 07 Jul 2015 Post subject: |
| Pete. |
 Pete. Super Spammer
 Posted: 21:36 - 07 Jul 2015 Post subject: |
Yes, like that. M8 x 1.25. Use copious amounts of lube.
Will the M8 clear through the hole in the pipe clamp? ____________________ a.k.a 'Geri'
| Moo. |
| WD Forte |
 WD Forte World Chat Champion
| Moo. |
| Pete. |
 Pete. Super Spammer
 Posted: 21:53 - 07 Jul 2015 Post subject: |
Ok, probably why the hole is straight then
Roll taps are unforgiving. They form the thread by moving the metal rather than removing it. They use a special high-pressure lube to keep the flanks of the tap from friction-welding to the metal. The best I can think of is to use EP90 oil (Extreme Pressure) as a tapping lubricant. If it starts creaking back out and add more oil. ____________________ a.k.a 'Geri'
| Pete. |
 Pete. Super Spammer
| Moo. |
| davebike |
 davebike World Chat Champion
 Posted: 09:12 - 08 Jul 2015 Post subject: |
Tapping size for M8 1.25 is 6.25 to 6.5mm 7mm is just about do able but 7.5 will give a rather loose thread but may get away with it I no go there
thread depth is 1/2 the pitch thread is on both sides so subtract Pitch from size add a bit for Clarence for tapping size ____________________ Dave
NC750Xdct + others at work !
davebike1@gmail.com |
| Raffles |
 Raffles World Chat Champion
| Aff |
 Aff World Chat Champion
| Pete. |
 Pete. Super Spammer
The last post was made 10 years, 265 days ago. Instead of replying here, would creating a new thread be more useful? |
