Best mod you've done to your bike?
Valver
PostPosted: 11:18 - 04 Feb 2005    Post subject: Best mod you've done to your bike? Reply with quote
What is the best modification you've made to your machine?
Race can/sprocket change/Re-map/K&N?
Mine would have to be my TRE. For £4.99 (ebay) you gain about 30bhp in the first 3 gears turning a bike thats already a neat wheelie machine into a beast that wants to backflip everytime you blip the throttle. Fitted in 30seconds and can be turned off at the flick of a switch(still ain't turnd it off yet, EVER).
Can't beat that for value for money.
cc123
Geez a joab?
PostPosted: 11:23 - 04 Feb 2005    Post subject: Reply with quote
Explain please??!! Confused I have no idea what that is....
I would say my race can but it's probably my Renthal chain and sprockets and also swapped to my Avon's from crappy Metzlers...
It became a totally different bike aftert that.
Dyno jet and filters are also on the cards tho! Laughing
Old bikes >>> https://www.bikepics.com/members/cc123/
HurtMePlease This post is not being displayed because the poster has bad karma. Unhide this post / all posts.
cc123
Geez a joab?
PostPosted: 11:34 - 04 Feb 2005    Post subject: Reply with quote
What does that do exactly? Is that for fuel injected bikes only?
Valver
PostPosted: 11:49 - 04 Feb 2005    Post subject: Reply with quote
Basically most newish thous and some smaller bikes are kinda restricted in the first couple of gears to stop you flipping them. The timing is retarded.
So a TRE kids your ECU into thinking your either in neutral all the time as mine does or in 5th gear.
Bikes that have a speed limiter can also be fooled by a similar device that makes the bike think its in 5th gear when really its in 6th. Therefor letting it rev all the way out in top gear and over 186mph. Razz
PostPosted: 11:56 - 04 Feb 2005    Post subject: Reply with quote
Can't say I found the TRE on my TL1000R that impressive, it does give it more edge in the first three gears but it'd still power wheelie without quite happily.
And they're ~£20 on eBay not £5. Confused
It was cheap and fitted to the bike when I bought it, but they're not that impressive really.
Best mod? I'd have to say down gearing my ZX6R was the best mod I've made to a bike. Much better acceleration, better value and gains than a TRE.
cc123
Geez a joab?
PostPosted: 12:06 - 04 Feb 2005    Post subject: Reply with quote
Is that just 1 tooth down at the front?
I found a difference changing my (fcuked) chain and sprockets to quality items....
TheShaggyDA
Repost Police
PostPosted: 12:07 - 04 Feb 2005    Post subject: Reply with quote
Best mod for a bike... probably the twin airhorns I fitted to my GPZ750R.
Bendy
Mrs Sensible
PostPosted: 12:19 - 04 Feb 2005    Post subject: Reply with quote
Downgeared it.
Race can, K&N, dynojet aren't all that noticeable (apart from the noise) but one tooth down at the front and four up at the back is. Smile
Have always fancied air horns though. Cool
ZaphodBeeble
PostPosted: 12:46 - 04 Feb 2005    Post subject: Reply with quote
I'd say that downgearing was one of the best things that I've done to a few bikes. Changes the whole feel of the bike. I'm not bothered about 100mph+ and I love corners. Mr. Green
Current bike: VTR1000F Firestorm. Previous: Firestorm (written off) - XJ600 Divvy - NSR125 - DT125 and a load of offroaders.
cc123
Geez a joab?
PostPosted: 12:49 - 04 Feb 2005    Post subject: Reply with quote
Hey, down-gearing....
Am I missing out??!! Confused
Bendy
Mrs Sensible
PostPosted: 12:53 - 04 Feb 2005    Post subject: Reply with quote
Yes.
Make a bike more fun at the end of the scale you actually use all the time.
Visitor Q
$25 whore
PostPosted: 12:54 - 04 Feb 2005    Post subject: Reply with quote
Yes.
Basically it lowers your top speed but ups the acceleration. Oh and wheelies.
If you like that sort of thing. Altho ive hear it a) loses your licence alot better and b) makes riding on motorways for long periods of time abit weird.
Oh and if your speedo doesnt run from your front wheel it will overread.
cc123
Geez a joab?
PostPosted: 13:05 - 04 Feb 2005    Post subject: Reply with quote
Hmmmmm....
Dunno if I'll bother, my bike wheelies well enough as it is and is quick enough out of corners.
Don't bother much with M,ways but still like to see the dark side of the speedo sometimes! Laughing
Bendy
Mrs Sensible
PostPosted: 13:08 - 04 Feb 2005    Post subject: Reply with quote
A little bit of downgearing can increase your top end, by letting the bike actually get to the redline in 6th, which the stock gearing doesn't always do.
cc123
Geez a joab?
PostPosted: 13:18 - 04 Feb 2005    Post subject: Reply with quote
I've heard of folks dropping a cog at the front and thats all, what kind of affect would that have?
Dr Nick
PostPosted: 13:19 - 04 Feb 2005    Post subject: Reply with quote
Downgearing Cool
Only cost me a couple of quid for the sprockets, different bike when there on, 2nd gear power wheelies?
is that it
Visitor Q
$25 whore
I think i still have the application somewhere, where you put in the top speed in all the gears with one ratio, then write in the new ratio and it tells you your top speed.
And then you guess that you'll t ake off like shit on a stick
Dr Nick
PostPosted: 13:21 - 04 Feb 2005    Post subject: Reply with quote
www.walesbikers.co.uk/gearing.exe
Made by maurice, excellent little program Thumbs Up
is that it
DukeRed
PostPosted: 13:30 - 04 Feb 2005    Post subject: Reply with quote
Since my speedo runs off the front sprocket can I just change the rear sprocket and not make a difference to the reading?
Jan
Enjoy Life There's Plenty of Time to be Dead
https://www.janoner.com
Visitor Q
$25 whore
PostPosted: 13:34 - 04 Feb 2005    Post subject: Reply with quote
Jan
No, because the speedo works by the assumption at x revs in y gear you will be doing z speed. Therefore if you are at x revs in y gear with a different final drive then you will be doing z speed minus a margin.
karen_moomin
PostPosted: 13:47 - 04 Feb 2005    Post subject: Reply with quote
The best mod to my bike....sticking BCF stickers on it!! Of course.
Mr C
PostPosted: 14:00 - 04 Feb 2005    Post subject: Reply with quote
30bhp from a TRE
bwahahahahahahahahahahaa Laughing Laughing Laughing Laughing Laughing Laughing Laughing Laughing Laughing Laughing Laughing Laughing Laughing Laughing
funniest thing I've seen in ages
187.3bhp = 201mph
cc123
Geez a joab?
PostPosted: 14:12 - 04 Feb 2005    Post subject: Reply with quote
30bhp from a TRE
Think valver was maybe mis-read...I'm sure he meant to say 'it feels like I've gained an extra....'
swaffs
PostPosted: 14:13 - 04 Feb 2005    Post subject: Reply with quote
best mod...
R&G crash bungs.
saved me a fortune !!!!
downgearing is next on my agenda after some super corsa sticky tyres going on soon.
Swaffs
Swaffs Photography |
BCF vinyl stickers
"Look not back in anger, nor forward in fear, but around you in awareness."
The last post was made 21 years, 245 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.16 Sec - Server Load: 1.06 - MySQL Queries: 13 - Page Size: 132.07 Kb
