Can't find piston rings! CRF250L
FuzzyBallz
PostPosted: 20:59 - 12 Jul 2015    Post subject: Can't find piston rings! CRF250L Reply with quote
When I bought the bike 5 months ago the oil stunk of petrol. I flushed it out and put new oil in. Recently it's developed a small oil leak, so I thought I would check the oil level before starting it and the oil level has gone just above maximum in the sight glass, and once again stinks of petrol.
Never done anything like this before but I'm going to give it a go myself.
Only problem I'm facing is I can't find the seal kit anywhere for the CRF250L. Lots of stuff for the CRF250X and CRF250R but not for the L.
Will it be ok to fit rings for an R or an X onto my L or will I run into problems?
Is there anything else I should consider doing whilst I am inside the engine?
As I said I've never done anything like this before so I'm going to be learning as I go along.
Cheers.
FuzzyBallz
PostPosted: 21:12 - 12 Jul 2015    Post subject: Reply with quote
So found some rings
https://www.ebay.co.uk/itm/Wiseco-Piston-Rings-3071XG-Ring-Set-for-Wiseco-78-00mm-/390788817887?hash=item5afcd423df
But still the other questions stand, anything else I should sort out at this point?
Or any advice on doing it will be appreciated, thanks.
kramdra
PostPosted: 21:26 - 12 Jul 2015    Post subject: Reply with quote
I would be asking why petrol is getting into the cylinder and not being burnt? Petrol will get past good rings, I dont think it is the problem.
How does engine run? compression good? burning oil? oil colour?
PostPosted: 22:07 - 12 Jul 2015    Post subject: Reply with quote
Have you checked the carb. Reason I ask is it can overflow and head down to the sump. Sounds more logical than rings.
FuzzyBallz
PostPosted: 07:17 - 13 Jul 2015    Post subject: Reply with quote
Hi Krandra, good point on the unburnt fuel thing, should be nothing but vapour left really?
Which leads me to think it could be a leaking injector?
The colour of the oil is like apple juice.
I haven't done any test but the engine seems to run ok, there is a slight smell of petrol from the exhaust when the bike is running but I'm guessing that's normal?
Vincent and Paddy, thanks for the replies, it's a fuel injected 4 stroke, but surely the same thing can happen through the injector?
PostPosted: 07:48 - 13 Jul 2015    Post subject: Reply with quote
Ah. Less likely then Crying or Very sad
Do a compression test and see if anything looks odd before ripping the head off.
jimspeed
PostPosted: 10:38 - 13 Jul 2015    Post subject: Reply with quote
It's going to be burning a lot of oil well before petrol would be contaminating the oil past bad ring's, I would look at why there is too much petrol getting to the cylinder in the first place, leaking injector or possible faulty temperature sensor causing it to run mega rich maybe.
Hyosung cruise 125(passed test on, sold) Kawasaki el 252 (better than expected but sold on) Kawasaki GPZ500S first "big"bike.(sold) ZZR600 E5..Z750 2007,ER5, currently on a 2008 Enfield bullet electra x and loving it..
,"Alpha-9: Is there any correlation between dyno rod and dyno kits?"
FuzzyBallz
PostPosted: 20:56 - 13 Jul 2015    Post subject: Reply with quote
So I pulled the injector and the tip is completely dry, so does that rule that one out?
I have noticed that there is a cable spliced into the rear light with a little splicing connector on the other end going to nowhere. If I am correct this is where people put aftermarket fuel controllers.
If it has had one in the past could it have anything to do with it?
I really wouldn't have a clue on testing o2 sensors or bridging connections, it's all like reading Japanese to me Sad
Best I could do is buy a new sensor, fit it and hope for the best.
kramdra
PostPosted: 21:28 - 13 Jul 2015    Post subject: Reply with quote
No, rear light feed is often used for relays and such, to give switched power for accessorys. If its a splice, I recommend removing and doing it properly as they are shit.
Fuel injector could be leaking. System is usually pressurised about 50psi. I imagine any leak would be very slow but over a long time could be significant. It does not take much petrol to make oil smell, probably only a tiny amount.
Prime fuel rail and injector off the bike?
The last post was made 11 years, 96 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 1.17 - MySQL Queries: 13 - Page Size: 79.47 Kb
