| Tamsin |
 Tamsin World Chat Champion
| Fizzer Thou |
 Posted: 18:53 - 14 Jul 2015 Post subject: |
It sounds like condensation in the float chamber.
Just drain it off into a container and see what appears.Then leave the fuel tap on for a while so as to wash it through
If all else fails then check the pilot jet ____________________ Just talk bikes.What else is there?
Always have a 'Plan B' |
| Tamsin |
| spannermonkey... |
 spannermonkey... Renault 5 Driver
 Posted: 19:39 - 14 Jul 2015 Post subject: |
Possible air leak at the carb. Like the inlet rubber split or fallen off. or the carb to engine rubber is split or not fixed down enough.
If your engine is sucking in more air it will run lean so opening the choke to get more fuel in. Depending if your choke is fuel or air controlling.
Good luck the post above could be right also. Modern fuel is rubbish. I've had bikes that run pants after leaving just a few days. That resulted in stripping and cleaning the carbs and would run fine till it was left alone for a while. best thing to do is, on your way home, turn the fuel tap off just before you get home, you have to learn how far away to do it, so the carb is then empty when you arrive home. ____________________ Current machines - Aprilia RS250. Kawasaki H1A 500. Past machines - Kawasaki ZX7r P6, Yamaha RD250E (the one that got away), BSA Racing bantam (revs over 10'000 sweet as), Yamaha RXS100, Suzuki GP100, Suzuki GS500K2 - best all year machine ever - come rain, sleet and snow just epic. |
| Tamsin |
| Tamsin |
| WD Forte |
 WD Forte World Chat Champion
| Tamsin |
| blurredman |
 blurredman World Chat Champion
 Posted: 10:24 - 15 Jul 2015 Post subject: |
Maybe the idle jet is clogged.
Check the jets  ____________________ CBT: 12/06/10, Theory: 22/09/10, Module 1: 09/11/10, Module 2: 19/01/11
Current: 1973 MZ ES250/2 - 18k, 1979 Suzuki TS185ER - 10k, 1981 Honda CX500B - 91k, 1987 MZ ETZ250 (295cc) - 40k, 1989 MZ ETZ251 - 51k. |
| Tamsin |
| moonzoomer |
 moonzoomer World Chat Champion
| Tamsin |
 Posted: 17:18 - 20 Jul 2015 Post subject: |
I think she needs a new fuel pipe anyway so I will sort that and put an inline in at the same time...  |
The last post was made 10 years, 262 days ago. Instead of replying here, would creating a new thread be more useful? |
