2 stroke tight gearbox after rebuild
PostPosted: 19:23 - 16 Jul 2015    Post subject: 2 stroke tight gearbox after rebuild Reply with quote
husqvarna 125
When I put the bottom end cases together the gearbox is very hard to turn, I can barely turn it using a lot of force. But if I loosen all the bolts I can hear this click (same click sound when I tighten bolts) And then the gearbox turns freely. I have reopened the case 4 times now already and checked for assembly-errors. I am using the same shims that already were there. What if I just throw the shims out, will that affect the bearings much?
misscrabstick
PostPosted: 20:07 - 16 Jul 2015    Post subject: Reply with quote
bearings probably not fully seated on the shafts coming through the cases into the primary drive, find a tube and put over the shafts against the bearings inner races and give them a smack.
PostPosted: 20:10 - 16 Jul 2015    Post subject: Reply with quote
If you're sure it's assembled right give the shaft ends a good hard crack with a plastic-faced hammer.
770
PostPosted: 20:15 - 16 Jul 2015    Post subject: Reply with quote
I can rotate the crank freely, I have just tried rotating the gearbox itself. I also tried without shims this time and it is still the same. Should the gearbox shaft be hard to turn in gear so long it is not connected to the crank?? It spins easily back and fourth but once I connect the case halves it is no go.. :/
Accuhaler
PostPosted: 17:07 - 17 Jul 2015    Post subject: Reply with quote
Correct term would be a mallet....
Taught2BCauti...
PostPosted: 08:59 - 18 Jul 2015    Post subject: Reply with quote
Don't throw the shims out - try removing all of them first to see if it solves the problem. If it does, you will need to put the correct thickness of shims back in to remove end-float, as the new bearings may be slightly bigger than the old ones.
The workshop manual should tell you how to measure end-float and setup the shims - (usually involves a dial-gauge or a micrometer).
Honda Varadero XL125(V8)
www.TheFutureIsHere.eu
PostPosted: 09:42 - 18 Jul 2015    Post subject: Reply with quote
Bearings are sized in hundredths of a mm or better. Shims will be taking up machining tolerances.
The last post was made 10 years, 243 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 1.06 - MySQL Queries: 13 - Page Size: 72.26 Kb
