| Henry2202 |
 Henry2202 Two Stroke Sniffer
 Posted: 12:51 - 18 Jul 2015 Post subject: At my wits end - Peugeot speedfight running problems |
So i bought this peugeot speedfight 2 100cc off ebay, hadn't been used for 5 years, very good condition, previous owner took for MOT and flew through.
I bought it as spares/repair as owner said it started and stopped after 30 seconds or so and i thought it sounded like main jet blocked.
So i receive the bike and clean the carb and jets and it ran perfectly, took it to work for 2/3 days, it guzzled fuel very quickly. I put £5 in and it was gone after 20 miles.
Anyway it is doing the same again now, it will start and run fine off the choke and then if you give it some throttle it will die, or just die after 30 seconds or so.
I've checked everything i can think of, spark, cleaned the carb 5 times, even bought another carb and choke, same problem, took head off and inspected, some light scoring, nothing major, cleaned air box, reed valve off etc. What next? It's doing my head in. Thanks |
| Robby |
 Robby Dirty Old Man
| unitynotsocri... |
 unitynotsocri... Banned
 Posted: 13:01 - 18 Jul 2015 Post subject: |
Check float level,check the jet SIZES. The previous owner may have changed them .
Check the exhasusdt is standard, a non standard exhasusdt means its been fiddled with,not like BBC dj s, also check the air filter is standard and the plug is clean ' deepthroat' pulling all the crap from the inside of plug. ____________________ nearly a normal tax paying tosser.......with ferrileness suzi100,cg125,cb125scb100n,cb175,cd100,cj250t,kh250,c15,125 bantam,super 6,rickman gs750,xt500,250rs,dt175,lifan125,dolomite1850,metro,Morris220ld,morrisfg,leyland princess,range rover,corsa,vw camper .now struggling with legs. MORE ORDER = MORE CHAOS |
| Henry2202 |
 Posted: 13:10 - 18 Jul 2015 Post subject: |
| Robby wrote: | To get through £5 of fuel in 20 miles, you're doing 20 mpg. I doubt that's possible on a speedfight, so I would be expecting fuel to be leaking - either somewhere between the carb and tank (if the tank is steel, it could be rusted through) or a knackered needle valve in the carb letting fuel through when the bike is standing and filling the crankcase, then chucking it out of the exhaust. Possibly out of the overflow on the carb, if it has one.
So, fuel system check - fuel tank and line for any evidence of fuel leaking.
You've mentioned cleaning the carb a lot, but not whether you inspected the needle valve for wear. Little point taking a carb off unless you're inspecting and cleaning it, you can just end up cleaning a broken part. |
Hi, Yes I've checked all of that. Even replaced the complete carb and still the same problem. When it was running it was very rough, spluttered a little so i thought the choke was staying on as this would explain fuel loss but I've changed the whole lot and same problem. Tank is plastic and no signs of leaking or fuel lines. |
| Henry2202 |
| Pol Anorl |
 Pol Anorl Banned
 Posted: 13:22 - 18 Jul 2015 Post subject: |
you must have a fuel leak somewhere... ____________________ GOOD GAME BODYGUARD: https://i.imgur.com/8WePGgf.jpg
20:30:37 Pyro.: I don't sort of like men, I take every advantage to choke on dick.
Jewlio Iglesias: You live in Liverpool - Chances are, the front door has already been kicked off the hinges |
| unitynotsocri... |
 Posted: 13:27 - 18 Jul 2015 Post subject: |
Crankcase seals? ____________________ nearly a normal tax paying tosser.......with ferrileness suzi100,cg125,cb125scb100n,cb175,cd100,cj250t,kh250,c15,125 bantam,super 6,rickman gs750,xt500,250rs,dt175,lifan125,dolomite1850,metro,Morris220ld,morrisfg,leyland princess,range rover,corsa,vw camper .now struggling with legs. MORE ORDER = MORE CHAOS |
| unitynotsocri... |
 Posted: 13:35 - 18 Jul 2015 Post subject: |
Or. Some little fcked with a pitbike vkeeps nicking the petrol? Or.....fraudulent garage pumps! ____________________ nearly a normal tax paying tosser.......with ferrileness suzi100,cg125,cb125scb100n,cb175,cd100,cj250t,kh250,c15,125 bantam,super 6,rickman gs750,xt500,250rs,dt175,lifan125,dolomite1850,metro,Morris220ld,morrisfg,leyland princess,range rover,corsa,vw camper .now struggling with legs. MORE ORDER = MORE CHAOS |
| Pol Anorl |
 Pol Anorl Banned
 Posted: 13:53 - 18 Jul 2015 Post subject: |
blame the petrol fairies. ____________________ GOOD GAME BODYGUARD: https://i.imgur.com/8WePGgf.jpg
| unitynotsocri... |
 Posted: 14:21 - 18 Jul 2015 Post subject: |
Witches? Quasi feminists? Tax collectors, ____________________ nearly a normal tax paying tosser.......with ferrileness suzi100,cg125,cb125scb100n,cb175,cd100,cj250t,kh250,c15,125 bantam,super 6,rickman gs750,xt500,250rs,dt175,lifan125,dolomite1850,metro,Morris220ld,morrisfg,leyland princess,range rover,corsa,vw camper .now struggling with legs. MORE ORDER = MORE CHAOS |
| ADAMH0 |
 ADAMH0 Borekit Bruiser
| Henry2202 |
| Henry2202 |
| Henry2202 |
| unitynotsocri... |
 Posted: 13:41 - 20 Jul 2015 Post subject: |
You could try a different coil or\ and cdi unit.....if available... ____________________ nearly a normal tax paying tosser.......with ferrileness suzi100,cg125,cb125scb100n,cb175,cd100,cj250t,kh250,c15,125 bantam,super 6,rickman gs750,xt500,250rs,dt175,lifan125,dolomite1850,metro,Morris220ld,morrisfg,leyland princess,range rover,corsa,vw camper .now struggling with legs. MORE ORDER = MORE CHAOS |
The last post was made 10 years, 255 days ago. Instead of replying here, would creating a new thread be more useful? |
