| czakal |
 czakal Nitrous Nuisance
 Posted: 14:54 - 25 Jul 2015 Post subject: pressure gauge accuracy |
So it's been a while since I remembered to check my tyres and my gauge says they're much below recommended pressure. How much accuracy should you expect from cheaper tyre pressure gauges? I have the Halfords Long Nose and MCN says it is accurate to less than 1 psi
https://www.ride.co.uk/upload/Ride%20Magazine/Product%20test%20pdfs/9%20SEP08%20Pressure%20gauge%20test.pdf
Is it realistic to expect such a level of accuracy from a pretty cheap tool? Some people like my former instructor didn't trust them very much.
Seb |
| RhynoCZ |
 RhynoCZ Super Spammer
 Posted: 15:08 - 25 Jul 2015 Post subject: |
Simple job, ask your mates, and or your local garage, and use their gauges as well. There is a very small possibility, that all the tyre pressure gauges, you are going to try, are going to be inaccurate in the same way as yours.
I've got a very cheap gauge with accuracy of 0.1 BAR, which is accurate more than enough. And I have taken the measurements with this, and 2 other fuel stations compressors. Shell's compressor was a bit off, but then, it does not really matter.
This one:
https://www.gsfcarparts.com/media/catalog/product/cache/1/image/9df78eab33525d08d6e5fb8d27136e95/9/8/983aa0890.jpg ____________________ '87 Honda XBR 500, '96 Kawasaki ZX7R P1, '90 Honda CB-1, '88 Kawasaki GPz550, MZ 150 ETZ
'95 Mercedes-Benz w202 C200 CGI, '98 Mercedes-Benz w210 E200 Kompressor |
| Taught2BCauti... |
 Taught2BCauti... World Chat Champion
 Posted: 09:29 - 26 Jul 2015 Post subject: |
I have a cheap digital one, similar to the picture above, and it normally lives in the boot of my car. Whenever I have to get a new tyre fitted at my local tyre fitter's, I check the tyre pressure with my gauge after they have checked it with theirs - because they have their's calibrated every 6 months.
It always reads the same, so that's good enough for me.
The gauges on my compressor, and my portable electric inflator are at least 10psi out. ____________________ Honda Varadero XL125(V8)
www.TheFutureIsHere.eu |
| MCN |
 MCN Super Spammer
 Posted: 12:16 - 26 Jul 2015 Post subject: |
| Howling TerrorOutOfOffice |
 Howling TerrorOutOfOffice Super Spammer
| MCN |
 MCN Super Spammer
 Posted: 12:25 - 26 Jul 2015 Post subject: |
Basirts want £7.99 now.
I have three of them though.  |
| kramdra |
 kramdra World Chat Champion
| kramdra |
| MCN |
 MCN Super Spammer
 Posted: 22:05 - 29 Jul 2015 Post subject: |
You should have only got a 120psi or 100psi
If you don't put more than 50psi in your tyres then a 60psi would do.
The lager the range the more inaccuracy can occur due to the travel of the Bourdon Tube.
They work like a coil spring and springs have differing rates under differing tensions.
i.e. A 60psi gauge will give much more precise readings of pressures around it's mid range 30-40 than a 160psi reading 30-40.
Just sayin'. |
| kramdra |
 Posted: 23:20 - 29 Jul 2015 Post subject: |
Trade off between a cheap higher quality 1% 160psi gauge or a more expensive 2.5% 60/100. 5 quid delivered is quite fucking good Anyway 1.6 psi error is far more accurate than necessary for a tire and a bit pointless unless your also comparing temperature.
I also suspect the ride test was a load of made up bollocks.. compare the stated resolution against the measured accuracy  |
| MCN |
 MCN Super Spammer
The last post was made 10 years, 199 days ago. Instead of replying here, would creating a new thread be more useful? |
