pressure gauge accuracy
czakal
PostPosted: 14:54 - 25 Jul 2015    Post subject: pressure gauge accuracy Reply with quote
So it's been a while since I remembered to check my tyres and my gauge says they're much below recommended pressure. How much accuracy should you expect from cheaper tyre pressure gauges? I have the Halfords Long Nose and MCN says it is accurate to less than 1 psi
https://www.ride.co.uk/upload/Ride%20Magazine/Product%20test%20pdfs/9%20SEP08%20Pressure%20gauge%20test.pdf
Is it realistic to expect such a level of accuracy from a pretty cheap tool? Some people like my former instructor didn't trust them very much.
Seb
RhynoCZ
PostPosted: 15:08 - 25 Jul 2015    Post subject: Reply with quote
Simple job, ask your mates, and or your local garage, and use their gauges as well. There is a very small possibility, that all the tyre pressure gauges, you are going to try, are going to be inaccurate in the same way as yours.
I've got a very cheap gauge with accuracy of 0.1 BAR, which is accurate more than enough. And I have taken the measurements with this, and 2 other fuel stations compressors. Shell's compressor was a bit off, but then, it does not really matter. Thumbs Up
This one:
https://www.gsfcarparts.com/media/catalog/product/cache/1/image/9df78eab33525d08d6e5fb8d27136e95/9/8/983aa0890.jpg
Taught2BCauti...
PostPosted: 09:29 - 26 Jul 2015    Post subject: Reply with quote
I have a cheap digital one, similar to the picture above, and it normally lives in the boot of my car. Whenever I have to get a new tyre fitted at my local tyre fitter's, I check the tyre pressure with my gauge after they have checked it with theirs - because they have their's calibrated every 6 months.
It always reads the same, so that's good enough for me.
The gauges on my compressor, and my portable electric inflator are at least 10psi out.
Honda Varadero XL125(V8)
www.TheFutureIsHere.eu
MCN
PostPosted: 12:16 - 26 Jul 2015    Post subject: Reply with quote
https://www.halfords.com/motoring-travel/tools-diy/tyre-inflators-pressure-gauges/halfords-mini-keyring-tyre-pressure-gauge
Very accurate and never failed yet.
PostPosted: 12:21 - 26 Jul 2015    Post subject: Reply with quote
I think Ride magazine did a pressure gauge group test and the £4.99 Halfords one won. [edit] Joint 3rd place. Smile
MCN
PostPosted: 12:25 - 26 Jul 2015    Post subject: Reply with quote
Basirts want £7.99 now.
I have three of them though. Smile
kramdra
PostPosted: 16:17 - 26 Jul 2015    Post subject: Reply with quote
Precision != accuracy.
I have ordered one of these
https://www.ebay.co.uk/itm/281742933375
kramdra
PostPosted: 20:10 - 29 Jul 2015    Post subject: Reply with quote
Wrong link, I ordered one of these https://www.ebay.co.uk/itm/171857015978 https://www.ebay.co.uk/itm/171871848478
Which arrived in a massive box.. because its massive Shocked 100mm diameter pressure gauge might look a bit odd on a 55mm diameter foot pump Laughing
MCN
PostPosted: 22:05 - 29 Jul 2015    Post subject: Reply with quote
You should have only got a 120psi or 100psi
If you don't put more than 50psi in your tyres then a 60psi would do.
The lager the range the more inaccuracy can occur due to the travel of the Bourdon Tube.
They work like a coil spring and springs have differing rates under differing tensions.
i.e. A 60psi gauge will give much more precise readings of pressures around it's mid range 30-40 than a 160psi reading 30-40.
Just sayin'.
kramdra
PostPosted: 23:20 - 29 Jul 2015    Post subject: Reply with quote
Trade off between a cheap higher quality 1% 160psi gauge or a more expensive 2.5% 60/100. 5 quid delivered is quite fucking good Thumbs Up Anyway 1.6 psi error is far more accurate than necessary for a tire and a bit pointless unless your also comparing temperature.
I also suspect the ride test was a load of made up bollocks.. compare the stated resolution against the measured accuracy Laughing
MCN
PostPosted: 09:14 - 30 Jul 2015    Post subject: Reply with quote
OK but two quid for a pressure gauge isn't going to get you much accuracy.
The Chinese are not too bothered by things precision. As long as it 'looks' accurate then it's AOK for them. Smile
The last post was made 10 years, 197 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.34 - MySQL Queries: 13 - Page Size: 73.04 Kb
