un-sticking speedo cable from speedo drive
Wonko The Sane
PostPosted: 12:22 - 27 Jul 2015    Post subject: un-sticking speedo cable from speedo drive Reply with quote
Need to replace the speedo cable on my ZZR 600, tried this morning and it's not a bad job to get to the back of the clocks to do it however the muppet that I am, I didn't attempt to disconnect the end that's had 2 years of motorway spray and road salt thrown at it which is quite well attached to the speedo drive.
Normally I'd just blast it with Gunk's 'liquid wrench' or similar penetrating oil, leave 20 mins, blast again and unscrew in an hour but the proximity to the brake disk makes me a bit wary of this approach,
If I stick a plastic bag or something to cover the disk will I be ok or is there a better way of getting this un-stuck?
Suntan Sid
PostPosted: 12:39 - 27 Jul 2015    Post subject: Reply with quote
If you've got time to spare, and you're worried about overspray, take the wheel off and soak the whole drive thing in a bath of penetrating oil.
Alternatively buy some penetrating oil that comes in a can, not a spray!
Is the drive held in place by a separate screw, or does the cable end just screw on to the drive housing?
Islander
PostPosted: 14:04 - 27 Jul 2015    Post subject: Reply with quote
Just mask it off with a piece of cardboard. Thumbs Up
Fisty
PostPosted: 15:43 - 27 Jul 2015    Post subject: Reply with quote
https://image.rakuten.co.jp/kami-tra/cabinet/03448688/img60564820.jpg?_ex=60x60
Fatter and faster than Fret
Wonko The Sane
PostPosted: 18:16 - 27 Jul 2015    Post subject: Reply with quote
Tried
screws onto the drive housing which sits between wheel and fork leg like a spacer,
unfortunately the bike is needed daily for work so will need to put a bit on each day until I can get it off.
Wonko The Sane
PostPosted: 18:15 - 28 Jul 2015    Post subject: Reply with quote
New drive unit on order from e-bay as it's simply sheared off, looks as though the whole lot's seized somehow
another thing to keep on top of greasing I guess.
samv
PostPosted: 10:07 - 29 Jul 2015    Post subject: Reply with quote
tried on of these? always works for me when something is really stuck
https://www.bol.com/nl/p/steelwood-griptang-225-mm/9200000010405364/
The last post was made 10 years, 203 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.54 - MySQL Queries: 13 - Page Size: 53.73 Kb
