| lingeringstin... |
 lingeringstin... Spanner Monkey
| Vincent |
 Vincent Banned
| lingeringstin... |
| Vincent |
 Vincent Banned
 Posted: 11:24 - 29 Jul 2015 Post subject: |
First one that comes to mind is the TS250, that's 72 x 64mm Bore & stroke, early ones were 66 x 72mm:-
"The design of the early motocross machine suffered because of its heritage, having been patterned after the dated Villiers engine, with it’s under square, 66 x 72mm bore and stroke set up. In the early 60’s when work began on the project, this was a perfectly good design, so Suzuki was doing little wrong by copying it. The internal architecture did hold the design back so for the TS model, parts and dimensions from the all new, road going, T500 were implemented, making the TS250 effectively half of this ground breaking twin-cylinder design with a more manageable, and reliable, 72 x 64mm bore and stroke". ____________________ Space Is Deep |
| lingeringstin... |
| Suntan Sid |
 Posted: 17:29 - 30 Jul 2015 Post subject: |
I may have misinderstood you, but you can buy a Suzuki TS250 Piston kit, up to 2mm oversize, for just under £36, from wemoto! ____________________ "Everybody needs money, that's why they call it money!"  |
| sickpup |
 sickpup Old Timer
 Posted: 20:56 - 30 Jul 2015 Post subject: |
| Kickstart wrote: | Hi
I have been told there is a large book around somewhere listing pistons with their dimensions.
If you find a copy then let me know as I need a piston suitable to go into a Gilera NGR250
K |
There is, the hi-level book that I used to match that rear sprocket up for you years ago if you remember.
The problem is with pistons you are looking at quite a few measurements.
Pin to Crown.
Pin.
Pin to skirt.
how much of the circumference is covered by the skirt, essential for the crank webs clearance.
and then you get extra stuff like ports.
Thing is none of the information is set out in an easy to read system but rather by bike and there are a lot of 2-strokes made in the last 40 years. |
The last post was made 10 years, 191 days ago. Instead of replying here, would creating a new thread be more useful? |
