piston dimensions needed (still)
lingeringstin...
PostPosted: 09:54 - 29 Jul 2015    Post subject: piston dimensions needed (still) Reply with quote
Been trying for some time to find any kind of reference info giving the actual dimensions of various two stroke pistons and had no luck at all.
I have resorted to looking up pictures of pistons and then enlarging the photos onscreen to measure them but that can't be very accurate.
Basically I'm just looking for a ready source of bog standard non reed valve two stroke pistons. Naturally I'd like to do as little specialist modification to the barrel as possible so I've been looking for pistons that are a close enough match for the standard ones and would require the least faffing about with. A bit of piston modification is easy enough, I've shortened skirts on a grinder to suit con rods before with no problem.
Gudgeon pin size isn't that important as I can use a different or modified con rod, and two stroke heads are easy to alter but piston crown height and the design of the skirts are important and that's the information I'm not finding very easily.
For instance some pistons have weirdly shaped bottom halves to accommodate weird shaped transfer ports and that sort of thing so what I really need is some kind of cross reference info or blueprint type drawings with measurements and so far I've not found anything useful.
Mainly looking at jetski and snowmobile pistons at the moment due to their ready availability and the fact they're designed to go like the clappers.
lingeringstin...
PostPosted: 10:47 - 29 Jul 2015    Post subject: deep holes Reply with quote
Ah well the actual bore size has been easy enough to find. What I was mainly looking at was pistons to shoehorn into MZ barrels. I've got a few barrels so mucking about with one or two is no big deal.
The 250 engine bore size goes from about 69mm to about 72-ish before you run out of liner and the 300cc barrel starts at about 75mm and can be bored out to about 80mm if need be, so there's lots of scope for bore sizes.
Obviously I'd rather not rebore too much initially so I can rebore later as I wear them out but there seems to be a lot of good quality jetski and snowmobile pistons made in exactly those sizes. I don't much care for MZ pistons and they're harder to get nowadays anyway.
lingeringstin...
PostPosted: 10:46 - 30 Jul 2015    Post subject: Yes exactly Reply with quote
I have been considering a Suzuki TS250 piston because as far as I can tell the only barrel modification I'd have to do id shorten the barrel top or bottom or both by a little bit so the transfer ports matched up. That's not too bad a job for the local wee man in his local wee machine shop so it's not expensive.
The ONLY problem I had with that idea was that as I understand it Suzuki no longer do those pistons and I'm unsure of how much after market support there is. Would be a bugger to alter a barrel to suit a piston only to find the pistons have become rare and thus "vintage" priced expensive. Haven't really delved into that yet.
For simplicity I just figured two stroke snowmobile and jetski pistons are a ready supply of spares and plus sizes for rebores.
I know just bunging in a complete Suzuki TS250 engine (or something completely else) would be a way to go but I've got a lot of spares for MZ like clutches, carbs, cranks and gearboxs already so upkeep is minimal if I stay with mainly MZ shite and I'm not going to get spendy with a 40 year old ratbike.
Suntan Sid
PostPosted: 17:29 - 30 Jul 2015    Post subject: Reply with quote
I may have misinderstood you, but you can buy a Suzuki TS250 Piston kit, up to 2mm oversize, for just under £36, from wemoto!
PostPosted: 19:24 - 30 Jul 2015    Post subject: Reply with quote
I have been told there is a large book around somewhere listing pistons with their dimensions.
If you find a copy then let me know as I need a piston suitable to go into a Gilera NGR250 Laughing
K
sickpup
Old Timer
PostPosted: 20:56 - 30 Jul 2015    Post subject: Reply with quote
K
There is, the hi-level book that I used to match that rear sprocket up for you years ago if you remember.
The problem is with pistons you are looking at quite a few measurements.
Pin to Crown.
Pin.
Pin to skirt.
how much of the circumference is covered by the skirt, essential for the crank webs clearance.
and then you get extra stuff like ports.
Thing is none of the information is set out in an easy to read system but rather by bike and there are a lot of 2-strokes made in the last 40 years.
PostPosted: 22:17 - 30 Jul 2015    Post subject: Reply with quote
Pin to Crown.
Pin.
Pin to skirt.
Darn useful book.
Some measurements are not that critical as I can get the barrel modified to suit (bit machined of the bottom to compensate for a small difference between gudgeon pin and crown, sleeve needed anyway so small difference in bore can be done).
Being a disk valve engine it saves some worries on shape.
K
The last post was made 10 years, 188 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.77 - MySQL Queries: 13 - Page Size: 66.11 Kb
