| Finney2003uk |
 Finney2003uk Two Stroke Sniffer
| simon1221 |
 simon1221 World Chat Champion
| Finney2003uk |
| alains |
 alains World Chat Champion
 Posted: 02:28 - 06 Feb 2005 Post subject: |
i put this on the wrong topic so :
turn the tap on and let it for a small time . turn off the tap and take off your carb without turning it upside down (by the way , have a look if it's no plate beetween the pipe and the reed valves) without turning it upside down , take off the float chamber without spreading any petrol inside , then mesure the hight (something like 20 to 24 mm) if less than that move down the small leg on the float , but not too much otherwise the valve will not close and petrol will overflow . then look your carb adjustments . you should have : main 145 , idle 45 , power 65 or 70 . prior of that you can order jets from https://www.dellorto.co.uk (£2.95 ex VAT and p&p) . they will ship them to you within 4 days . afterwards clean your air box . adjustments on the pilot screw is thight and 2 1/2 turns unscrewed . idle is set at 1500 rpm after 5 mn running (when the temperature indicator goes in the white) ____________________ the worst day fishing is better than the best day working |
| Whitetrash |
 Whitetrash Banned
| Whitetrash |
 Whitetrash Banned
The last post was made 21 years, 142 days ago. Instead of replying here, would creating a new thread be more useful? |
