nsr engine help
Finney2003uk
PostPosted: 17:33 - 05 Feb 2005    Post subject: nsr engine help Reply with quote
hey i got a nsr 1991 model i have just had a full engine rebuild i put the engine back in the bike bumped it toke a bit to get it started but worked had a quick go and put it back toke it out 2 days l8er it started first time with choke on revs died down turned choke off set off 5 secs l8ers it back fired well like a hiss not a bang and died it has compresion and wants to start but just doesent any ideas please help
simon1221
PostPosted: 20:17 - 05 Feb 2005    Post subject: Reply with quote
How high did you rev the engine?
You should be running it in very carefully after a rebuild so nor more than 5000revs for 100miles, 6k for another 100miles etc.
How do you know it has compression? Does it fire?
Finney2003uk
PostPosted: 00:54 - 06 Feb 2005    Post subject: Reply with quote
dident go over 5 revs
alains
PostPosted: 02:28 - 06 Feb 2005    Post subject: Reply with quote
i put this on the wrong topic so :
turn the tap on and let it for a small time . turn off the tap and take off your carb without turning it upside down (by the way , have a look if it's no plate beetween the pipe and the reed valves) without turning it upside down , take off the float chamber without spreading any petrol inside , then mesure the hight (something like 20 to 24 mm) if less than that move down the small leg on the float , but not too much otherwise the valve will not close and petrol will overflow . then look your carb adjustments . you should have : main 145 , idle 45 , power 65 or 70 . prior of that you can order jets from https://www.dellorto.co.uk (£2.95 ex VAT and p&p) . they will ship them to you within 4 days . afterwards clean your air box . adjustments on the pilot screw is thight and 2 1/2 turns unscrewed . idle is set at 1500 rpm after 5 mn running (when the temperature indicator goes in the white)
Whitetrash This post is not being displayed because the poster is banned. Unhide this post / all posts.
The last post was made 21 years, 139 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 1.18 - MySQL Queries: 13 - Page Size: 47.87 Kb
