| Sigsy |
 Sigsy L Plate Warrior
 Posted: 21:13 - 01 Feb 2005 Post subject: Yet another bad starter thread.........[SOLVED] |
Alright lads?
My bike(Kawasaki ZXR400 L2) isn't starting at the mo, hence, was hoping some of you may be able to offer me some advice!
A bit of history first:
* Brought L2 model in August last year. My first big bike, 32k on the clock, owner was using it on a daily commute but was in good condition. However, i knew i would need to replace bits as wear & tear cropped up. Bike rode really well and no apparent probs.
* Put about 600 miles on her when she started losing all revs when i came to a stop with the clutch pulled all the way in. Still rode ok apart from that. Eventually started backfiring and then wouldn't start at all.
* Put into P&H motorcycles in Brighton who had her in their workshop for over a week trying to find the problem. All electrics were thoroughly tested and working fine. Eventually found that the wiring loom had corroded and needed replacing. Job done (October) - bike was on top again
I'd decided to leave my bike in my Nan's garage from end of November until end of Feb as i knew i wouldn't use it much etc. Bike was fine when i put her in storage. I didn't get time to clean any of the bike or spray with GT85 etc.........i'd ridden in wet conditions to my Nan's. Stupid i know.
Anyway, i manage to see bike at end of December so it'd been idle for a month. Took about 5 clicks of the start button to get her going. Everything was cool.
I went back to my Nan's last weekend. The weather was good so i thought i'd go for a spin. I sprayed some muck-off and rinsed with quite a bit of cold water. Sprayed some GT85 to get ride of any moisture and let it evaporate. Bike started on 2nd attempt Went for a quick spin just around town and she rode as well as ever.
Stopped for an hour. It had started to rain slightly by this point so bike was exposed outside. Went back and she started first time. Side stand up, drop into 1st and it cuts out. Tried again numerous time's and it wouldnt' start. Eventually put the choke full-bore and she starts but was idling at 6k rpm! Adjusted the idle bolt a little which made a difference but dropped into first and she was revving between 1.5 - 6 for no reason. I had to push her home in the end.
The next day i had a play and she started (again with choke full-bore). I changed the throttle cable adjuster slightly but not much difference. When she was running, if i blipped the throttle, she revved but it didn't seem half as responsive as usual.
She's back in my Nan's garage until i can get back upto Worcester at the end of Feb. Hopefully by then i might be able to have some idea of what it is!
Any ideas? The battery was fully charged and tank about 1/3rd full. Knowing that it isn't the wiring loom this time, i still think it is electrical maybe? I've read in the Haynes manual for Kawasaki Fours that 'erratic running faults and problems with the engine suddenly cutting out in wet weather can attributed to to leakage from the high tension (HT) lead and spark plug cap.' Obviously you are then supposed to clean it because of the accumulation of mud and grime around the lead and cap. Any idea where the HT lead and spark plug cap are? I'm guessing near the bottom of the bike?
But then i guess it could be a problem with the petrol pump? Hence, why it wasn't blipping as well as usual? Could be an air leak causing the erratic running? other stuff such such as oil & coolant is topped up.
Bear in mind that she could do with a good service to be honest! How much are you guys paying for a thorough service?
Sorry about the essay!!!
Sigs
| Scotsman37 |
 Scotsman37 World Chat Champion
 Posted: 21:55 - 01 Feb 2005 Post subject: |
You're going to like this link as it's to do with service manuals in PDF format to do with varying models of ZXR400 and other help too.
https://wwr.dyndns.org/ZXR400/list.htm |
| bish777 |
 bish777 World Chat Champion
| bish777 |
| yambabe |
 yambabe World Chat Champion
 Posted: 01:46 - 03 Feb 2005 Post subject: |
Apparently I am being told it could be due to carb icing? ____________________ Sod falling in love, I wanna fall in chocolate.  |
| slowarse |
 slowarse Nitrous Nuisance
 Posted: 20:03 - 03 Feb 2005 Post subject: |
i have heard kawasaki's do suffer badly with carb icing.
i had something similar with my bike a while ago, turns out it needed the carbs cleaned and balanced. run like a dream since!  |
| bish777 |
| Dom_ |
 Dom_ Points Mean Prizes
| instigator |
 instigator Super Spammer
| bish777 |
| bish777 |
| Sigsy |
 Posted: 09:23 - 04 Feb 2005 Post subject: |
Cheers for all the reply's lads. I'll keep you posted on the outcome though it won't be for about a month at least!
Sigs |
| sickpup |
 sickpup Old Timer
| Dom_ |
| sickpup |
 sickpup Old Timer
| Dom_ |
| sickpup |
 sickpup Old Timer
| Dom_ |
| sickpup |
 sickpup Old Timer
| Sigsy |
 Posted: 12:18 - 07 Apr 2005 Post subject: |
Peeps,
Thanks for all your replies all them weeks ago! Though i'd update on what the score is. I was at my Nan's 3 weeks ago and booked my bike in for an intermediate service. Got the garage to collect the bike etc.
Anyway, the mechanic went for a ride and rang me to let me know about any probs. He seemed to think that it was still restricted (i never get it above 100 to be honest), front dics are warped (since brought some used straight one's which i'll fit myself), pads needed replacing (i brought some to fit myself), front wheel bearings are shot (which will have to wait).
I got them to start the service and got a call a day later saying that No.2 carb was pissing out fuel. Therefore i said just 'sort it'. Turns out that all the carbs had been played with in the past and all needles needed replacing. So heading back to Worcester tomorrow to pick bike up in afternoon and ride her £370 in all. Will fit discs and pads afterwards.
Sigs |
The last post was made 21 years, 180 days ago. Instead of replying here, would creating a new thread be more useful? |
