Rs125 not starting again, urgent help needed.
Jali2098
PostPosted: 08:54 - 02 Aug 2015    Post subject: Rs125 not starting again, urgent help needed. Reply with quote
Recently had problems starting my rs125, after changing the battery the bike worked fine for about a week but then it would not start again.
The voltage in the battery reads 11.2v.
The previous owner had an alarm installed but removed it upon selling it leaving a wire that is not connected to anything, could this have drained the battery?
Help is needed urgently.
PostPosted: 08:59 - 02 Aug 2015    Post subject: Reply with quote
Tried charging the battery?
Mysteriass
PostPosted: 10:04 - 02 Aug 2015    Post subject: Reply with quote
Does sound like it's not charging or the battery is knackered. The lowest the battery should "sit" is around 11.6v and even that's not good.
Get a multimeter out and check the DC voltage across the battery terminals while the bike is running. Give the bike some revs and see what happens. The voltage should jump up to about 14.8v with some revs and sit around 13v on idle. Turning lights on should drop the voltage to about 11.8v - 12.3v
When I put my wiring together I had a ridiculous issue whereby the main negative earth to the frame from the battery had a dodgy connection. Give the wires a wriggle all along the loom - starting with the main NEG/POS while reving the engine a bit and watching the meter at the same time. Start with simple stuff before you worry about replacing regulators and rectifiers.
Meanwhile, you're going to have to charge the battery every night until you find the problem.
That loose wire...dunno. Depends how the alarm worked, if it was an immobilizer of some sort it's more likely to cause an issue with the ignition I'd imagine.
PostPosted: 17:38 - 02 Aug 2015    Post subject: Reply with quote
Love how the OP hasn't bothered to reply despite it being "urgent".
Nobby the Bastard
Harley Gaydar
PostPosted: 18:23 - 02 Aug 2015    Post subject: Reply with quote
Do we really need to explain how to check whether the charging circuit is working again?
Triumph Sprint ST 1050
Jali2098
PostPosted: 06:11 - 03 Aug 2015    Post subject: Reply with quote
The bike works fine once you charge it but only for a couple of days.
Mysteries -I will charge the bike and check the voltage when running.
Wafer thin ham - that would be due to being at work.
Jali2098
PostPosted: 14:57 - 03 Aug 2015    Post subject: Reply with quote
Vincent - The current voltage is 11.2 and it is not starting. Before it was turning over but now no noise is made when the stater button is pressed.
PostPosted: 17:00 - 03 Aug 2015    Post subject: Reply with quote
It would appear your battery isn't being charged then. .....
MCN
PostPosted: 17:51 - 03 Aug 2015    Post subject: Reply with quote
Should be a Karma button for 'Threads based on false pretences'. Mad
Very Happy
PostPosted: 17:59 - 03 Aug 2015    Post subject: Reply with quote
It's not being charged. Find out why.
Jali2098
PostPosted: 11:54 - 04 Aug 2015    Post subject: Reply with quote
MCN - I work from 8:30 am till 2 pm then 4 pm till 9 pm, that would be why I haven't replied.
As for the noise, before it was turning over when the starter button was pressed but now no noise is being made.
MCN
PostPosted: 12:14 - 04 Aug 2015    Post subject: Reply with quote
But... but...
I never said nufin. Sad
What are you doing from 2-4?
You SHOULD have been back on t' Interweb updating yo thread man.
This is not some sort of casual acquaintance forum on here you know.
Some of us take these things seriously. Mad
Very Happy
PS
Battery
Connections
Starter Switch/Button
Or starter clutch (if it has a one)
delsol
PostPosted: 17:29 - 08 Aug 2015    Post subject: Reply with quote
OP, these really do work and last if treated with a bit of care, not for rough handling or chucking around, can't go wrong with a multimeter.
https://www.ebay.co.uk/itm/DIGITAL-LCD-VOLTMETER-MULTIMETER-CIRCUIT-TESTER-AMMETER-AC-DC-METER-OHM-YELLOW-/141093479832?pt=LH_DefaultDomain_3&hash=item20d9d3a598
The last post was made 11 years, 37 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.53 - MySQL Queries: 13 - Page Size: 89.48 Kb
