How do I choose a boiler?
DrSnoosnoo
PostPosted: 07:40 - 03 Aug 2015    Post subject: How do I choose a boiler? Reply with quote
I'll keep it short.
We're buying house.
House is old has old 2 tank boiler set up for hot water and no Central Heating.
I want to remove these and replace with a combi boiler.
There are 1 thousand million combi boilers.
How do I choose the right one?
Property description:
3 Bed semi
1 Bathroom
will want (maybe) 7 rads and one of those towel rack/radiator things for the bathroom.
ta. Thumbs Up
andyscooter
PostPosted: 07:47 - 03 Aug 2015    Post subject: Reply with quote
buy a Worcester bosch one
Taught2BCauti...
PostPosted: 08:05 - 03 Aug 2015    Post subject: Reply with quote
Go to B&Q and get them to calculate the size of boiler you need, then shop online for the BTU rating they give you.
My guess, because my house is about the same spec as yours, would be 80,000BTU.
Honda Varadero XL125(V8)
www.TheFutureIsHere.eu
Just_James
PostPosted: 08:23 - 03 Aug 2015    Post subject: Reply with quote
boiler size calculator
Current Bikes / Projects: 1999 Rieju RS1 50
Previous bikes - 1986 DT125R (field bike), 1989 KX250, 1980 KX420 (with 500cc big bore), 1992 YZ250, 1988 KX500, 1989 XR250R, 1988 VFR400R NC24, 1999 Cagiva Mito 125, 2008 Rieju RS2 50 , 1993 Honda NSR 125
arry
PostPosted: 08:28 - 03 Aug 2015    Post subject: Reply with quote
You need to know the flow rate of your main supply too. No point buying a combi that can heat more water per minute than you're flowing otherwise you're just paying extra for something you can't use to its full effect
panrider_uk
PostPosted: 08:43 - 03 Aug 2015    Post subject: Reply with quote
Any rough idea of how much a plumber would charge to replace an existing boiler with a new one (me supplying the boiler)?
Just hanging it and modding the existing pipework so shouldn't be too expensive right?
Thanks
PostPosted: 08:47 - 03 Aug 2015    Post subject: Reply with quote
Laughing Laughing Laughing Laughing Laughing Laughing Laughing Laughing Laughing Laughing Laughing
arry
PostPosted: 09:08 - 03 Aug 2015    Post subject: Reply with quote
Including the boiler as long as you're not in a mansion - 1500 to 2000 quid fitted
DrSnoosnoo
PostPosted: 09:57 - 03 Aug 2015    Post subject: Reply with quote
Very helpful replies so far thanks. I'll use that calculator thingy but thinking about the water pressure, arry. How would I find out?
Quick calculator used despite not fully understanding it. It says 7.9 kW.
I'll have a look but does that number seem stupidly low/high, have I used the calculator really badly?
arry
PostPosted: 10:33 - 03 Aug 2015    Post subject: Reply with quote
You use a flow meter. Effectively attaches to the nearest tap to the mains supply and then you run the tap at full flow - it measures the amount of water through and gives you the flow rate
DrSnoosnoo
PostPosted: 10:52 - 03 Aug 2015    Post subject: Reply with quote
I didn't think it was that simple. I thought it might be contacting Yorkshire Water and they bring a man out who goes into holes in the floor and whatnot.
Wonko The Sane
PostPosted: 11:25 - 03 Aug 2015    Post subject: Reply with quote
this
I had Dave Scargill who's based in Barnsley do mine (yup, current house) as he's done two boilers for me mum and one each for each sets of grandparents so knew he'd not be bullshitting me about what I need / don't need.
price was cheaper than the electrical re-wiring despite how much copper pipe was used!
DrSnoosnoo
PostPosted: 11:37 - 03 Aug 2015    Post subject: Reply with quote
Wonko The Sane wrote:
this
I'll look into the Worcester Bosch lot then when I'm going ahead. My uncle is a plumber, I think he lives in Todmorden now, so he said he'll do it for me. He's a good tradesman and makes a fair wage doing good work.
I think there might be a rewire job on at my new place too, the joys of old(er) houses. The woman who left this house is 103 and just gone into her home. We met the nephew who is a roofer and told us he'd not long done the attic, some joists and insulation. Because he did it for his aging Aunt, I'd suspect he did the best job he could for her.
Unfortunately it's not up your neck of the woods. I'm gonna be living North Leeds.
Al
PostPosted: 18:07 - 03 Aug 2015    Post subject: Reply with quote
With a combi you're going to want at least a 24kw ish boiler for your direct hot water. The heating load is normally far lower on a smallish house so you can't size to that as it won't be powerful enough to heat the water.
A modern boiler will modulate down to a lower output when just on heating.
Yamaha FZR400RR 3tj
My Instagram Thingy
Jewlio Iglesias This post is not being displayed because the poster is banned. Unhide this post / all posts.
stevo as b4
PostPosted: 19:15 - 03 Aug 2015    Post subject: Reply with quote
I would think that a 3bed house of a fair size is getting close to the practical limits of having a combi boiler. There is no good reason to choose a combi in a large home IMO, and they also tend to have a shorter life span than other types of boiler.
But if you want a make to recommend, then just my personal preference would be a Valliant unit.
Wonko The Sane
PostPosted: 19:20 - 03 Aug 2015    Post subject: Reply with quote
this
Chap I recommend is Barnsley based so Leeds isn't far but if your uncle can do it then go with that.
It's worth considering gutting the house before moving in doing all the re-wiring etc.
A friend of mine (who's an electrician) has literally stripped back to the brickwork and boarded and skimmed the walls, he's put electric heating in all round and a hot water immersion heater and now has no gas on the theory it's not that much price difference and surely we're going to run out of gas / price increase and switch to electric anyway.
not sure if this is a plan or not.
I've had to re-do some jobs when I've found something I wasn't expecting trying to live in the house while working on it, depends if there's been many bodges (like in my house)
arry
PostPosted: 19:26 - 03 Aug 2015    Post subject: Reply with quote
Jewlio Iglesias wrote:
Why on earth would you put a crappy combi in?
Care explain?
My combi is powering a 4 bed house with twin reception rooms, dining room, 2 showers and a bathroom over 3 levels.
The previous boiler was in 23 years and wasn't well maintained but still lasted that long. The new one was under 2K fully installed.
Poor value for money driving your decision? Poor economy? Please add detail if you would
Raffles
PostPosted: 19:54 - 03 Aug 2015    Post subject: Reply with quote
Free standing ones.
What are they?
arry
PostPosted: 20:24 - 03 Aug 2015    Post subject: Reply with quote
Free standing ones. Of course, no plumber will install them these days, but if you can find one who will 'sign it off'....
Is that code for something I'm not referencing?
Wonko The Sane
PostPosted: 20:36 - 03 Aug 2015    Post subject: Reply with quote
arry wrote:
Care explain why not a 'crappy combi'?
Free standing combi boilers?
Yep, Worcestser Bosch make a couple but I was told I didn't need anything that big, the only one fitted by the chap who did my system he put in a church / village hall.
my average size (physical size) wall mounted boiler happily powers 13 radiators over 3 floors with no issue while being the size of a large kitchen wall cupboard.
Fowlersrs
PostPosted: 07:46 - 04 Aug 2015    Post subject: Reply with quote
Here we go, vailant or Worcester will see u get a decent combi, Worcester do larger floor standing combis with a storage of water for larger properties. It all depends on how much hot water demand you have, are your showers electric or are they mixer units?
Don't let anyone put you off a combi, I've been in the trade 15 years and fit boilers daily for the largest supplier of LPG gas in the country. For 2/3 bedroom properties there is normally no more cost effective way of providing your heating/hot water
grr666
PostPosted: 08:27 - 04 Aug 2015    Post subject: Reply with quote
I deliberately bought bigger than I needed, but always planned to extend my house at some point in time.
I have a Bosch Worcester Greenstar 30CDI, it's installed in my loftspace as I don't have any suitable external
facing walls in my kitchen. It's a 30kW unit. Run via a wireless digital thermostat/timer/controller unit. Currently it's running my
hot water and 6 moderately sized radiators. At present I have just a single bathroom which has an electric shower so
is about 90% cold water used in there, the plan is to refit the bathroom and get rid of the electric shower,
but I'll only be able to do that after I have built the downstairs shower room giving us an alternative place to
get clean, wife goes to gym a lot so we can't manage without facilities for very long at all.
In a few weeks I intend to add a 7th rad in the lounge before winter arrives, There used to be a Baxi gas fire/back boiler
setup in there which was el crappo. There's now a small wood burning stove in the fireplace instead, but it's a bit of a faff
and it quickly gets too warm in there if you use it. For those evenings when it's just a bit chilly, a nice double rad
will take the chill off. When it's really cold I fire up both the stoves 1@ 14kW (kitchen) and 1@ 10kW (Lounge) and them plus the
central heating warms up the house like a motherfucker.
Got my boiler through a London based building contractor I used to work for, they get good prices on boilers
because they buy loads. Of course, they claim their VAT back so it actually cost me £877 all in including
horizontal flue and digital wireless timer unit.
Link is not where I bought mine from Wink Just to demonstrate model/type.
https://www.directheatingsupplies.co.uk/worcester-greenstar-30cdi-system-boiler?gclid=CPeS0dr5jscCFRQatAodZ1sE1Q
panrider_uk
PostPosted: 10:31 - 04 Aug 2015    Post subject: Reply with quote
The wireless thermostat/controllers are great.
I use one of these which can also be controlled over t'internet.
Clicky
The last post was made 10 years, 169 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 0.72 - MySQL Queries: 13 - Page Size: 136.46 Kb
