BMW k75s Gear indicator
Lsdinc
PostPosted: 11:31 - 03 Aug 2015    Post subject: BMW k75s Gear indicator Reply with quote
Hi all,
I have a 1990 BMWk75s. 41k on dial.
I have been riding it the last month pretty constantly (about 2k in last month) and in the last week the gear indicator on the instrument panel has stopped working. It does not display neutral and does not show the correct gear.
The bike does not know it is in neutral either, when I start the bike I have to pull the clutch to start even if I'm in neutral. On a side note the speedo stopped working for a short period and started working again so it may be a cable issue.
The instrument panel does have a lot of condensation on it, I'm not sure if that would be a factor. I'm not sure if it is a problem with the gearbox or just a loose cable, I have tried to look around in the internet but i can not find any other posts on this subject.
Other then that the bike is running great and all the other lights on instrument panel are working well.
Any advice would be great, thanks a mill
Les
MCN
PostPosted: 11:34 - 03 Aug 2015    Post subject: Reply with quote
I'm not sure of the bike model but I had a similar problem on my R1200GS.
The problem was the switch on the gearbox.
If you can look for a parts diagram it may be that. You can try whipping it out and cleaning it first.
I had a rummage around here
https://realoem.com/bmw/enUS/partgrp?id=0563-EUR-01-1990-K569-BMW-K_75_S_0563%2C0572_
Mibby this No 19
https://realoem.com/bmw/enUS/showparts?id=0563-EUR-01-1990-K569-BMW-K_75_S_0563,0572_&diagId=23_1154
Lsdinc
PostPosted: 11:57 - 03 Aug 2015    Post subject: Reply with quote
thanks a million, I'll take a look at the transmission switch.
WD Forte
PostPosted: 12:53 - 03 Aug 2015    Post subject: Reply with quote
Yup, clean all connectors first
Dont use WD40, use proper switch cleaner or even ACF50
K's like many bikes are known to get the weather in the connectors
and hopefully that's all your problem is.
There was a Goretex membrane mod for K type clocks
can't recall when it became standard fitment or if it was any good or not though.
bikers smell of wee
Oldie
PostPosted: 16:04 - 03 Aug 2015    Post subject: Reply with quote
The gear position switch on the back of the gearbox is tricky to access, but just might be the problem as they are prone to water penetration.
However, it might be the large connector behind the clocks unit. I'd try wiggling that first to see if you get a result. The do come loose.
jjdugen
PostPosted: 16:18 - 03 Aug 2015    Post subject: Reply with quote
The gear position switch on the back of the gearbox is tricky to access, but just might be the problem.
More than likely.
Yes it does, but on one of these things, that is far too easy.
The last post was made 11 years, 64 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.53 - MySQL Queries: 13 - Page Size: 48.13 Kb
