roofing felt for bike ramp?
Ribenapigeon
PostPosted: 13:35 - 04 Aug 2015    Post subject: roofing felt for bike ramp? Reply with quote
Is roofing felt allright to use as a grippy surface for a ramp?
Cheers.
Matt B
PostPosted: 13:39 - 04 Aug 2015    Post subject: Reply with quote
The gritty surface will wear off very quickly and the felt will rip easily.
You are better off with ant-slip paint or strips of anti-slip tape.
MCN
PostPosted: 13:52 - 04 Aug 2015    Post subject: Reply with quote
Is it a metal, cement, masonry wood ramp?
Chicken wire is a fix if you can be arsed stapling it onto a wooden ramp.
The anti-slip method is another.
Ghetto is to paint with exterior gloss.
Sprinkle some coarse sand over the wet surface.
When it dries over paint the sand and paint.
A couple of coats may be needed to bond the sand in place.
You can repair it any time then.
For a more posher look, mask off the border before putting down the sand. Looks like a pro did it.
The anti-slip tape can be expensive.
Ribenapigeon
PostPosted: 14:26 - 04 Aug 2015    Post subject: Reply with quote
I had anti slip tape but the stuffs expensive and has mostly come off over the last two years. Its a wood ramp.
The ghetto idea sounds good. I might do a test bit tonight. Thanks.
t121anf
PostPosted: 15:12 - 04 Aug 2015    Post subject: Reply with quote
Plenty of nature parks use chicken wire on wooden walk ways must pass Health an Safety so I'd to that if it's wooden.
robertw95
PostPosted: 15:42 - 04 Aug 2015    Post subject: Reply with quote
You can buy anti slip paint like what another poster said you just mix the grippy sand stuff into the tin and layer it on, no need for 2nd coats
07 Dt125r, sv650s k8, zx6rr 04
The last post was made 11 years, 60 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 2.14 - MySQL Queries: 13 - Page Size: 47 Kb
