which grease?
stirlinggaz
PostPosted: 00:37 - 05 Aug 2015    Post subject: which grease? Reply with quote
Hi,
the bike im currently playing around with needed new steering head bearings.
I took the cheap route & just bought the ball bearings.
which grease should I be using when re-assembling?
When I took the bike apart, the grease that was in there was red, thick & sticky.
Im presuming its that lucas "red + tacky" stuff. Is this any good?
the grease I have, is just standard lithium stuff which I think is a bit thin for this & all the other greases I have are unsuitable (copper, silicone, red rubber etc)
should I just buy some of the lucas stuff? even though im unlikely to use more than a spoonful, once a year at most.
its cheap enough on ebay (about a fiver for small cartridge)
TL/DR? what grease for steering head bearings?
cheers,
GAZ
Lyam
PostPosted: 02:46 - 05 Aug 2015    Post subject: Reply with quote
moly grease
sickpup
Old Timer
PostPosted: 05:43 - 05 Aug 2015    Post subject: Reply with quote
Lyam wrote:
moly grease
Or maybe bearing grease?
temeluchus
PostPosted: 06:58 - 05 Aug 2015    Post subject: Reply with quote
Any lithium bearing grease will do the trick. No need for anything extravagant.
Lucas red and tacky is indeed red, but isn't the only red grease out there. It is fine for this should you buy some.
Raffles
PostPosted: 11:01 - 05 Aug 2015    Post subject: Reply with quote
I use this stuff.
It's a good all-round grease and I use it on pretty much everything.
weasley
PostPosted: 12:50 - 05 Aug 2015    Post subject: Reply with quote
Steering head bearing don't do much spinning or get hot but do take a bit of an axial pounding (more if you drop wheelies). A simple multi-purpose lithium grease will be fine.
PostPosted: 13:23 - 05 Aug 2015    Post subject: Reply with quote
On steering head bearings I would use an EP lithium grease.
MCN
PostPosted: 14:02 - 05 Aug 2015    Post subject: Reply with quote
I'd look for a waterproof grease. It's a PITA to get to so anything you can do to help the grease last is good.
I wonder why they don't have grease fittings on the bastirts anyway?
Probably the sealed for life (pre-packed) bearings used for head stocks.
lihp
PostPosted: 15:05 - 05 Aug 2015    Post subject: Reply with quote
Link to "waterproof" grease?
stirlinggaz
PostPosted: 15:19 - 05 Aug 2015    Post subject: Reply with quote
Hi,
the grease I use most is just cheap "lithium based multi purpose grease" according to the blurb on the tub, but I thought it might not be thick enough to hold the loose balls in place & would also get washed out (through time)
normally I would fit tapered needle bearings & give then a coating of the cheap grease but the only reason im replacing the balls on this bike is cos I lost a couple of the balls Smile
it looks like they were done quite recently & I would have got away with just tightening it up...
anyway, if I buy some of this "red & tacky" stuff, it wont do any harm to the bike, right?
I suppose it will come back n handy....for something
cheers,
GAZ
PostPosted: 16:12 - 05 Aug 2015    Post subject: Reply with quote
https://www.foxsmarineandcountry.com/products/morris-k-99-waterproof-grease-af2-74911?utm_medium=cpc&utm_source=googlepla&variant=428002849&gclid=CjwKEAjw6IauBRCJ3KPXkNro1BoSJAAhXxpyDBJ0OtfWC7y3PNH0t5EmbFzbbLdv3CVzIqh3VJl_8BoCqcXw_wcB
Use this on my narrowboat stern tube but I think not needed for steering bearings. Laughing
lihp
PostPosted: 16:17 - 05 Aug 2015    Post subject: Reply with quote
Polarbear wrote:
The tub says Water Resistant though Wink
PostPosted: 16:20 - 05 Aug 2015    Post subject: Reply with quote
lihp wrote:
Works, is waterproof. In contact with water continuously on my boat. However I'm certainly not saying its right for steering bearings, it's for stern tubes.
lihp
PostPosted: 16:22 - 05 Aug 2015    Post subject: Reply with quote
Fully submerged in water? I use plenty of water "resistant" grease in work, but never seen anything marketed as waterproof. But then, I've never worked on a boat though either Laughing
Raffles
PostPosted: 16:33 - 05 Aug 2015    Post subject: Reply with quote
Read and weep Wink
lihp
PostPosted: 16:41 - 05 Aug 2015    Post subject: Reply with quote
excellent resistance to water wash out
PostPosted: 17:24 - 05 Aug 2015    Post subject: Reply with quote
A stern tube is always fully submerged in water. Boat propellers don't work well in air Wink
edit to say boat propellers Laughing
The last post was made 11 years, 58 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 1.68 - MySQL Queries: 13 - Page Size: 96.07 Kb
