Can't remove thermostat? and bolt.
lukehanham
PostPosted: 23:49 - 05 Aug 2015    Post subject: Can't remove thermostat? and bolt. Reply with quote
I need some advice on how i should go about removing this here:
It seems extremely stiff to me and i dont want to break it!
https://puu.sh/jqP1X/4ea9f95ab5.jpg
https://puu.sh/jqP3G/58fcc840b8.jpg[/img]
CaNsA
PostPosted: 23:52 - 05 Aug 2015    Post subject: Reply with quote
Heat.
lukehanham
PostPosted: 23:55 - 05 Aug 2015    Post subject: Reply with quote
While i am working in the next few days am i okay just to run the bike without the big golden bolt and thermo? It's about a 15 minute drive each way to work?
bikenut
PostPosted: 12:27 - 06 Aug 2015    Post subject: piston Reply with quote
good looking piston you have there!!
placer the head in some hot water and watch the thermostate open, or not, check temp and see temp stamp on thermostate.....
nuts about bikes
MCN
PostPosted: 12:55 - 06 Aug 2015    Post subject: Reply with quote
Some Yee-Haaaw may have used a sealant on the thread.
Heat will get it loose.
Sister's/Mum's/Wife's/Partner's hair drier on II probably wont melt the aluminimumimum head.
+1 on the piston too. Smile
lukehanham
PostPosted: 23:41 - 06 Aug 2015    Post subject: Reply with quote
Yeah, some idiot( totally not me ) decided he would run 25 jet sizes too small, ended up exploding the top end give or take.
Will try a hair dryer!
Scootaloo
PostPosted: 11:06 - 07 Aug 2015    Post subject: Reply with quote
Here's one for you.
How many thermostats does it take to change a bolt?
Real answer: Place it onto a vice. Heat up the bottom and top of the bolt using blowtorch for about 30 seconds and spray some GT85 on that too. Then Remove bolt normally using socket.
(CBF125 - 09) (CBF125 - 11) (CB-1 - 89) (CBF500 - 06) (Push Bike) (CB-1 - 90) (XL125 - 01) (VF500 - 83) (GPZ500 - 94) (GPZ500 - 95) (GPZ500 - 87) (XV535 - 94) (XV535 - 94) (GPZ500 - 87)
Chuffin Nora
PostPosted: 00:14 - 08 Aug 2015    Post subject: Reply with quote
Scootaloo wrote:
Place it onto a vice. Heat up the bottom and top of the bolt using blowtorch for about 30 seconds and spray some GT85 on that too --- but not before you extinguish the blowtorch! Then Remove bolt normally using socket.
Thumbs Up FTFY! Shocked Laughing
There's a fine line between integrity
The last post was made 11 years, 45 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.96 - MySQL Queries: 13 - Page Size: 54.64 Kb
