Head Swap Yamaha Majesty 250 scoot
wots
PostPosted: 13:25 - 06 Aug 2015    Post subject: Head Swap Yamaha Majesty 250 scoot Reply with quote
Replacing cylinder head on Yamaha Majesty 250, replacing as one of the studs snapped, too short, can't drill. Managed to get a good replacement head for £35 delivered.
As it's a single cylinder, I think ...
1) Whip off carb and ancillaries, it's liquid cooled.
2) Undo tensioner
3) Remove chain sprocket and allow chain to slip off
4) Undo head in right order.
5) Remove head
6) Clean faces and fit new gasket
7) fit head and guide chain through
Then reverse etc.
Where will the bottom end timing mark be? I haven't looked as yet, wanted to ask before I start tearing it apart.
Cheers
barrkel
PostPosted: 15:55 - 06 Aug 2015    Post subject: Reply with quote
Check for small circular plug on the side (typically with a groove in it, suitable for turning with a coin). Should have visibility onto something crank-attached with a mark for TDC.
The last post was made 11 years, 56 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 1.08 - MySQL Queries: 13 - Page Size: 32.16 Kb
