running on one cylinder when hot
MCN
PostPosted: 21:13 - 07 Aug 2015    Post subject: Reply with quote
Well if there is a weak mixture then it will get hot.
If it has a weak injector then swap to feed another cylinder and see if the fault follows the injector.
Nemo
PostPosted: 21:53 - 07 Aug 2015    Post subject: Reply with quote
Which rear cylinder? Or both? Seeing as they're a v4
Previously owned: Kawasaki KH125, Suzuki GP125, Suzuki GX 125, Honda CB125 TDC '83, Honda ntv 600, Kawasaki ER5, Kawasaki ZZR600, Aprilia RSV 1000 Mille
Now own: Ducati 848 evo
Nemo
PostPosted: 22:06 - 07 Aug 2015    Post subject: Reply with quote
That makes more sense.
As said buggered injector. Do you know if there'ds an fi light on?
RhynoCZ
PostPosted: 22:27 - 07 Aug 2015    Post subject: Reply with quote
Can you check the injector unit?
PostPosted: 22:59 - 07 Aug 2015    Post subject: Reply with quote
N cee thirty wrote:
it's strange, he says it comes on (FI light) when it starts to get warmed up after ten mins and thats when the cylinder drops out aswell
Why not just get the error code and see what the fault is?
https://forum.svrider.com/gallery/data/500/sv650_error_codes.jpg
MCN. This post is not being displayed because the poster is banned. Unhide this post / all posts.
monkeybiker
PostPosted: 08:56 - 08 Aug 2015    Post subject: Reply with quote
https://www.google.co.uk/webhp?sourceid=chrome-instant&ion=1&espv=2&ie=UTF-8#q=sv650%20fault%20codes
bikenut
PostPosted: 10:50 - 08 Aug 2015    Post subject: valve clearance Reply with quote
hydraulic tappets on this bike?????
does it loose compression when it misfires?? and when were the valve clearances checked / adjusted?
nuts about bikes
PostPosted: 13:13 - 08 Aug 2015    Post subject: Reply with quote
N cee thirty wrote:
how do you get the code up? all he says is that is the fi light comes up and i'm 180 miles away so i can't check
Stuff a paperclip in the dealermode connector. The connector is under the seat on the left.
https://forums.sv650.org/showthread.php?t=55459
Best thing to do is pull the connector out of it's hiding place and ride the bike with the pillion seat off. When the FI light comes on stop the engine with the red switch but LEAVE THE IGNITION ON. Find the connector, connect the two wires with a paperclip, read the code on the dash.
All codes are wiped when the ignition is turned off, so you have to read the code before that.
The last post was made 11 years, 38 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.49 - MySQL Queries: 13 - Page Size: 99.49 Kb
